Old 07-30-2023, 07:08 PM   #1
DEGUZZI
DEGUZZI's Avatar
DEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to all
KA24DE Vacuum Hose Routing
Took some time to clean up this diagram and redraw a few things for better clarity:
Planning on doing versions that are color coded as well, but if anyone has any corrections or suggestions, let me hear them
IG: de_guzzi // Build Thread
DEGUZZI is offline   Reply With Quote
Old 08-02-2023, 02:51 PM   #2
AKADriver
AKADriver's Avatar
See if you can find a proper diagram for the '93.5 and '94, it's a one year variation with no butterflies but S13 otherwise. Basically deletes one solenoid and the associated lines and the routing of the lines on that distribution block/solenoid bracket bolted to the head is different as a result.
S14 is also different since it has no butterflies, no PAIR, and they don't use the vacuum distribution block either (the S14 head doesn't even have the tapped holes for it, as I discovered when I was putting my car together with PAIR deleted and trying to figure out this same stuff).
