Old 12-04-2004, 11:14 PM   #1
01SaturnL200
Banned from the Marketplace
01SaturnL200 is making a name for him/her self01SaturnL200 is making a name for him/her self
Send a message via AIM to 01SaturnL200 Send a message via Yahoo to 01SaturnL200
electric fan install.....
ok, well i got my 240 running good, but my electric fan is broke so it likes to run hot at idle, i bought a universial electric fan to replace the mechanical fan, what all is involved in doin this? i know to take off the fan blade and clutch but do i need to get a new pulley, belt, etc.....? please help me out, i tried searchin
01SaturnL200 is offline   Reply With Quote
Old 12-04-2004, 11:21 PM   #2
240silvia
240silvia's Avatar
240silvia is an unknown quantity at this point
Send a message via AIM to 240silvia
SR
If you bought an electric fan, all you have to do is run the power and ground, clip in the relay if you have one.... and you are done.
240silvia is offline   Reply With Quote
Old 12-05-2004, 12:05 AM   #3
CA20Guy
CA20Guy is an unknown quantity at this point
Send a message via AIM to CA20Guy
Since we are on the subject, what relay would you tap into? Is it supplied with the fans? How would it work if they were thermostatically actuated?
CA20Guy is offline   Reply With Quote
Old 12-05-2004, 12:54 AM   #4
240silvia
240silvia's Avatar
SR
That I don't know. I had mine come on with the ignition. It was just on all the time. It came with it's own relay though.
Old 12-05-2004, 01:22 AM   #5
CA20Guy
Yeah my buddy did that with his he installed.
Old 12-05-2004, 06:05 AM   #6
01SaturnL200
cool, thanks guys
Old 12-06-2004, 04:27 PM   #7
s14 blacktop
s14 blacktop is an unknown quantity at this point
Send a message via AIM to s14 blacktop Send a message via MSN to s14 blacktop Send a message via Yahoo to s14 blacktop
your Hi fan relay, oh and you better raise your rpms if you put 2 of them cuz mine drained my battery.
s14 blacktop is offline   Reply With Quote
Old 12-06-2004, 06:14 PM   #8
meatish
meatish's Avatar
meatish is a well-known jackass
Clutch fans are far superior to electric fans. If you can, use the stock clutch fan. Otherwise, just hook up power and ground, for a ghetto set up you can run a relay into the cab and install a switch to just turn them on manually.
Mr. Pibb + Red Vines = CRAZY DELICIOUS
-Dont wanna be a drifter no more..
Im not a drifter i just crash a lot.
meatish is offline   Reply With Quote
Old 12-06-2004, 09:00 PM   #9
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
Operate the fans off of a thermo switch. Otherwise you run the possibility of running you engine too cold with the fans running all the time, especially when it gets below 0*c, even if it doesn't get that cold.
The clutch fan is better, but if done right electric fans can do just the same...
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 12-06-2004, 10:11 PM   #10
01SaturnL200
i read somewhere that u can get a lower radi hose w/ a thermal sensor out of a newer 240, is this tru, if so how do i hook it up?
Old 12-06-2004, 10:46 PM   #11
goodjuan
goodjuan's Avatar
goodjuan is an unknown quantity at this point
Send a message via AIM to goodjuan
Maybe this article can help you decide on an electric fan.
http://home.satx.rr.com/silviaweb/radiator_test.htm
It's pretty interesting and also includes some data that provides some insight into the clutch versus electric fan debate.
goodjuan is offline   Reply With Quote
Old 12-06-2004, 11:12 PM   #12
timmybgood
timmybgood is an unknown quantity at this point
get an adjustable thermostat that you can just put on the wires for the fan, problem solved. heavy throttle has them. i have one. i recommend
1995 SE
timmybgood is offline   Reply With Quote
Old 12-07-2004, 09:28 AM   #13
01SaturnL200
thanks for the link, it helped me alot
Old 12-09-2004, 10:26 PM   #14
01SaturnL200
thanks for the help everybody, i got it installed today, the wiring is a lil rigged but ill fix that tomorrow. i have the fan turn on when the car does and off when the car does. works just like a charm :-D
