![]() Join Date: Oct 2012
s13 Speed Sensor (VSS) Differences - Q's & pics
I have a '92 dual cam that I manual swapped. The speedo and odometer weren't working consistently when purchased auto, and is still the same after swap, so I figured I'd replace the speed sensor.
Ordered this one off ebay saying it was from a 91-94 manual dual cam. Unfortunately, it is too big to fit into my tranny. I searched around and saw that the automatic VSS is larger in diameter than the manual one, so I want to confirm that. Is it possible the single cam speed sensors are also larger in diameter, or is that only for automatics? I'm not sure what year my trans is. I've circled the main differences below. The one I bought is the pink one, the red I already had. Differences: - diameter of cylinder that inserts into the trans on pink one is larger than red one - black nubby pins are different lengths (don't know if that means anything) - mounting tab is flipped about 180 degrees on pink one, thus the wire harness is on opposite side of sensor If anyone has any knowledge to share about the differences or observations, please share. Curious as to which sensor I ended up actually buying. ![]() ![]() ![]()
'92 vert, '10 accord coupe |
![]() Join Date: May 2002
All S13/S14 manual speed sensors are the same diameter and fit in the same transmission hole. S14 and kouki 180SX have a different connector style but the fitment into the transmission is the same.
Specifically S13 240SX SOHC and DOHC manuals '89-'93 are the exact same part number. The one with the pink gear looks like an auto speed sensor to me, return it. I think the black rollpin on your old sensor just isn't inserted all the way. |
It is true that automatic transmission speed sensors are usually larger in diameter than manual transmission sensors. This may explain Poly Track why the one you bought (pink) does not fit.
automatic speed sensor, ka24de transmission vss, manual speed sensor, speed sensor, vss |
