Old 02-26-2025, 03:13 AM   #1
Izento
Izento's Avatar
Izento is an unknown quantity at this point
CA18DET Dyno Results: GT2871r 48Trim 91 Cali Pump Gas
Here you go guys, just thought I would share. 252whp/222wtq. It's far lower than I thought. Here are the specs.
CA18DET 8 port GT2871r 48T (normal compressor trim is 52)
256/256 Tomei Poncams
Supertech pistons 0.5 overbore
2.75 intake w/ HKS intake
3 in full exhaust (turbine housing, downpipe, cat, and catback)
r8 coilpacks
Fuel/Electronics:
780cc Deatschwerks injectors
R35 MAF
Apexi Power FC Apexi
AVCR Boost Controller
Apexi Power FC Commander
Drivetrain: ACT 6 Puck Clutch (330 ft lb)
KAAZ 2 Way
Still can't figure out how to post pics on this site so visit my thread I guess on Nico. Just thought I would share info on here too. Also not a thread to bash SRs/CAs, but just wanted to share info.
https://forums.nicoclub.com/izento-s...70089-300.html
Izento is offline   Reply With Quote
Old 02-28-2025, 02:54 PM   #2
slider2828
slider2828's Avatar
Just do [img] link to .jpg or png [/img] thats it
Well you have a smaller A/R you won't make big numbers but your torque to hp numbers look good and I am sure response is good too..... get a bigger a/r I assume you just want over 300? I assume pump gas too? and what ecu
Turn and Burn!
Old 03-03-2025, 08:00 AM   #3
PoorMans180SX
PoorMans180SX's Avatar
Just need to turn the boost up mate.
