Old 12-11-2004, 08:43 AM   #1
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
SR SR warming up
hey guys, i dont know if im the only one that expiriences this or others have the sme problem... but my car dosnt like to warm up now that its getting cold here in northern VA. Tipically on my Jeep and mother's camery, i just let it idle for maybe ahout 30 seconds to a minute, and you can see the temp has raisen just a little. By then, i take off but drive gentally until it reachs the normal op temp which does not take long at all. Now... with my SR i can let it idle there for an hour and it still be cold. The radiator and motor will be some what warm but its not enough for the temp gauge to show a difference. Eve nwhen i start driving, it stays pretty cold unless i boost. Now this worries me because if its not at normal op temp, then the piston rings have not expanded to their normal sizes where they can handle the boost so i'll be getting blow by....
anways i just wanted to share my situation and i was hoping maybe someone can help me out of if someone else a common problem, even tho most people dont even pay attention to their temp.
another question.. does anyone know what temp are in between the lines on the temp gauge, and what temp is safe for my motor to have a little fun?
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 12-11-2004, 11:23 AM   #2
wutangben
wutangben is making a name for him/her selfwutangben is making a name for him/her self
Send a message via AIM to wutangben
I am having the same problem. I did my swap a couple months ago, and it would warm up just fine. At the track it would even start to get too hot if i didn't let it rest inbetween runs. (i don't have any fans on it right now). Anyways, since it's been cold, I can drive it for an hour and it still won't warm up. At times when im sitting in traffic the needle might go up to the middle for a few seconds, but then once i start driving again, it goes back down. It especially sucks because the heat isn't even warm, and when it is, it's only for a few seconds. I'm not burning any coolant because my coolant levels have stayed the same. Is this just a thermostat issue?
Ben
wutangben is offline   Reply With Quote
Old 12-11-2004, 11:24 AM   #3
wutangben
Oh and i don't even have a cool setup. I'm running the stock radiator, no fans, SMIC, and 13psi on my T25...
Old 12-11-2004, 01:49 PM   #4
Silverbullet
same dude, mother fucking same. wont warm up unless i boost... which i dont really want to when its cold.
HouseBuyers365.com
Old 12-11-2004, 11:30 PM   #5
Mikel
Mikel is an unknown quantity at this point
Thermostat could be stuck open.
What gauges are you guys using? If it's the stock gauge, there could be a difference between the SR20 sender and the KA sender.
These are just general suggestions, I'm a 240/SR20 noob
Mikel is offline   Reply With Quote
Old 12-12-2004, 12:31 AM   #6
evilimport
evilimport's Avatar
evilimport is an unknown quantity at this point
running 13 psi on a SMIC is a bad thing to do...potentially....heat soaked IC's are not good...off subject, I know.....
You douche bags bring your A-game?
S14 Zenki face owns all.
evilimport is offline   Reply With Quote
Old 12-12-2004, 12:41 AM   #7
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
Maybe on the SR at idle there is not enouhg fuel even being burned to create much heat, I let my KA idle for the amount of time it takes to some a cig in -20 degree celcius and it warms up fine.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 12-12-2004, 07:42 AM   #8
Silverbullet
read harder. It dosnt warm up when i drive either. I have to boost hard.
last night cruising to the spots, my motor didnt even warm up to nearly what its supposed to be until i raced a turboed LS/VTEC Integra. On my way back home, my motor pretty much was cold for the whole 30 minutes of driving on the high way.
HouseBuyers365.com
Old 12-12-2004, 10:22 AM   #9
wutangben
No one seems to be analyzing our problem correctly (cept for maybe mikel). My guess is that our thermostats are bad... anyone else?
Old 12-12-2004, 10:47 AM   #10
Dousan_PG
Dousan_PG's Avatar
here's my setup
i have a water temp gauge
billion thermo koyo radiator
and heats up fast when driving around..at my op temp pretty quick
i say thermo too, maybe stuck in the open position (dead thermo)
easy to replace as well
make sure to rebleed system really well too
Aaron
Pink GodziRa
Old 12-12-2004, 04:25 PM   #11
Inland180
Inland180's Avatar
Inland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant future
Send a message via AIM to Inland180
like dousan said. Its probably your thermo but it can also be that your water system has some air trapped in it. Thats what usually happens to all the cars. Try to bleed your water system real good. Ad some antifreeze and should be good. if not then next thing would be to change your thermo.
PTE6262 Full-Race Twin Scroll FTW!
Feedback LINK
Inland180 is offline   Reply With Quote
