Old 12-12-2004, 08:34 PM   #1
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
s13 Nismo Transmission Mount for S13
I tried to install this used NIsmo mount that I bought used, and found out that I needed a lot more than just the actual mount. When I bought it, I didn't know that it needed any other nuts/bolts or whatever, and I tried to put it on, and it was definately missing a few parts.
What I'm asking is, does anyone have a write-up or pictoral thingie on how to install? Or even a picture of all the parts that compose the Nismo tranny mount.
95zilvia is offline   Reply With Quote
Old 12-12-2004, 11:48 PM   #2
nismojunkie
nismojunkie's Avatar
nismojunkie is an unknown quantity at this point
Take what you have to the NISSAN dealer and go to the parts counter.
They should be able to look up any and all parts needed.
I'm lucky, cuz the NISSAN parts guy here is a 240 nut
_________________________________________
Curt Kuepfer A.K.A. NISMOjunkie
89 Pignose SE Coupe
Best Buy Mobile Installer, Ohio
nismojunkie
nismojunkie is offline   Reply With Quote
Old 12-13-2004, 05:23 AM   #3
projectRDM
projectRDM's Avatar
The Nismo mount is identical to the OE mount, just a stiffer rubber. You should use all your existing hardware on the car. Nothing additional is required.
FORMERLY R240NA
Old 12-13-2004, 11:08 PM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Should be cake, support the tranny on jacks, unbolt the tranny cross member off the chassis, remove cross member off the stock mounts and there should be 2 more bolts holding the mount onto the tranny.
Old 12-14-2004, 05:05 AM   #5
95zilvia
Ok I know how to install it. All i want is a picture of all the parts that came in the box!
Old 12-14-2004, 09:01 AM   #6
projectRDM
projectRDM's Avatar
There are no parts. You use your existing hardware.
FORMERLY R240NA
