Old 12-14-2004, 04:11 PM   #1
smellslikecurry
smellslikecurry's Avatar
Trader Rating: (33)
smellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfection
Feedback Score: 33 reviews
ahhhhhhhhhhhhhhhhhhhhhhhhhhh
ahhhhhh....dudes coming to pick up my wheels right now and when i was taking off one of the lugs it cracked (one of the tuner lug nuts... looks like this)
now i cant take off the wheel because the key jst keeps spinning...what should i do
smellslikecurry is offline
Old 12-14-2004, 04:27 PM   #2
AlligatorBling
AlligatorBling's Avatar
AlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choices
Send a message via AIM to AlligatorBling Send a message via Yahoo to AlligatorBling
oh damn... your gonna have to butcher it to get it off...
AlligatorBling is offline
Old 12-14-2004, 05:13 PM   #3
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
chisel it off..
btw what kind are they so i dont go and by them?
o nevermind, i never buy the "tuner" kind.
Hi
Var is offline
Old 12-14-2004, 05:24 PM   #4
Ritz S14
Ritz S14's Avatar
That's why boys and girls, you torque your wheels down.
Ritz S14 is offline
Old 12-14-2004, 05:42 PM   #5
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
That's precisely why I NEVER torque my wheels.
I hand tighten them only. That way they never get stuck.
Good stuff.
www.KA24DEvelopment.com
orion::S14 is offline
Old 12-14-2004, 05:44 PM   #6
orion::S14
orion::S14's Avatar
Oh, did you get them off?
You could try a wheel shop, they have what's bascially an "EZ Out", but in reverse...it's has an open end, and will grab onto the nut and tighten as you try to turn it off (lefty-loosey).
Good luck.
- Brian
Old 12-14-2004, 06:12 PM   #7
smellslikecurry
Trader Rating: (33)
i hand tightened it too! i had to get tuner kinds b/c my advans have tiny holes for lug nuts and these are the skinniest ones i could find - still barely fit
Old 12-14-2004, 06:12 PM   #8
s14 blacktop
s14 blacktop is an unknown quantity at this point
Send a message via AIM to s14 blacktop Send a message via MSN to s14 blacktop Send a message via Yahoo to s14 blacktop
you could use a star shaped socket, a little bigger than the size of that tool you have. Hammer it in there and hold the socket wrench pressed when trying to take it out, hopefully it will come out.
s14 blacktop is offline
Old 12-14-2004, 06:43 PM   #9
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
you guys can "NOT" torque your wheels down all you want. I like to keep my rotors from warping, and my studs from snapping off.
The nut itself cracking just means you got fucked nuts!
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline
Old 12-14-2004, 09:37 PM   #10
a2low240
a2low240 is an unknown quantity at this point
Send a message via AIM to a2low240
Hammer a 12pt socket on there and get it off that way. Just don't miss and hit the wheels.
Signature Exceeds Forum Limits
a2low240 is offline
Old 12-14-2004, 11:19 PM   #11
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
Lug nut cracked...hah, high quality part.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline
Old 12-14-2004, 11:24 PM   #12
HyperTek
yah i also believe in proper torquing.. Just recently one of my tires blew out on the road, and as I was trying to break the "tuner" nuts off, the idiot shop that installed my tires made them maaaaaad tight, it was startin to strip my key lock....
Woah those lug nuts say "Zenki"... they must be jdm, guess they wont work on my chuki or kouki huh.....
Keep it Classy
HyperTek is offline
Old 12-14-2004, 11:28 PM   #13
Ritz S14
Ritz S14's Avatar
Truthfully I don't use a torque wrench. I've been working with wheels/rims/tires for enough years to have a mental idea on how much 60 ft/tq is. If you do, do it this way, just make sure all the lugs have an equal torque. Don't have one tigther than the other.
Never torque the shit out of your bolts till you shit in your pants, that's a big no no. Will warp rotors, and be a bizzatch to remove.
Ritz S14 is offline
Old 12-15-2004, 12:13 AM   #14
SR240DET
SR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud ofSR240DET has much to be proud of
Send a message via AIM to SR240DET
if you want.. you can waste a cheapo 19mm socket... pound the shit out of the socket over the lug... and use a breaker bar.. this is what i had to do on my buddys gorila nuttz...
SR240DET is offline
Old 12-15-2004, 12:16 AM   #15
Ritz S14
Ritz S14's Avatar
Gorilla nuts actually uses a 17mm, and you don't even have to pound them
I'm pretty sure a 19mm socket will not fit in the hole of his wheels. Just try what someone said with the oversized torx bit, and good luck.
Ritz S14 is offline
Old 12-15-2004, 12:44 AM   #16
SR240DET
oh yeah... that was with my buddys STOCK s14 alloys.... my bad... good luck..
SR240DET is offline
Old 12-15-2004, 07:01 AM   #17
smellslikecurry
Trader Rating: (33)
i cant fit any socket over it because half of the lugnut cracked off, so basiccally its like a half circle where you putthe key in...i see no other choice but to drill
Old 12-15-2004, 08:04 AM   #18
s14 blacktop
Well if its broken off use some channellock to try to get it off or even better get the kind that lock so that way theyl stay on the nut, get a pipe,big enough to fit over the plyers, and undo it that way.
Old 12-15-2004, 11:07 AM   #19
AzNCmB
AzNCmB's Avatar
AzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond repute
Send a message via AIM to AzNCmB
do you guys think that lug broke because it was over torqued, or is poo ass lugs?
I recently bought MUTEKI open lugs for my 5 lug swap from phase2....any of you guys are using those?? what do ya think bout them?
thanks
AzNCmB is offline
Old 12-15-2004, 11:57 AM   #20
rainier
rainier's Avatar
rainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud of
Send a message via AIM to rainier
damn mine are just like that but silver. hope my shit doesnt break on my like that.
rainier is offline
Old 12-15-2004, 01:24 PM   #21
smellslikecurry
Trader Rating: (33)
s14 blacktop, i tried that already and all it did was break off more chunks off the lug nut...the lug nut is complete shit!!!!!! such cheap quality....i didnt torque it on too tight cuz im smarter than that this shit sucks!
Old 12-15-2004, 02:27 PM   #22
s14 blacktop
Man that sucks ok go to sears and get a stripped nut remover get one that will sink its teach into the out side diameter of the nut, I think they come four in a pack, each one being a different size, well try to get the set that looks closest to your lug nut size bigger and smaller, and hammer it in so it will get a grip on the nut and HOPEFULLY it will remove it .
Old 12-15-2004, 02:36 PM   #23
SirWarrior
SirWarrior is an unknown quantity at this point
Antisieze is cheap. Been using it for long time and didn't have a problem.
Oh yeah, torquing it to right spec helps.
also, when getting lug nuts, spend some $$ on a decent set.
the ones off ebay are shit, get a set of gorilla ones, proven quality!!
I mean those little bolts hold your wheel on!!!!!! Don't be cheap!!!!
92 FastBack - Project
98 SE - Daily Driver
SirWarrior is offline
Old 12-15-2004, 05:03 PM   #24
kay_arsen
kay_arsen's Avatar
kay_arsen is on the path to ruinkay_arsen is on the path to ruin
Send a message via MSN to kay_arsen
aahahahaha that shit happened to me
its the way you twist it out to much pressure on a certain point.
now i hold it straight.
i had to torch it out sad day for my rims
kay_arsen is offline
Old 12-15-2004, 06:46 PM   #25
mellojoe
mellojoe is an unknown quantity at this point
you could try to stick the head of a bolt in there.... maybe tack weld it in place.
Then use two nuts on the bolt. The two nuts can squeeze together. then use that to loosen the lug nut
mellojoe is offline
Old 12-15-2004, 09:49 PM   #26
speeddreamz
speeddreamz's Avatar
speeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nice
Send a message via AIM to speeddreamz
If im understanding it correctly, the lug nut is pretty much in several pieces, yet it is still holding on to some stud threads, but spinning on those?
Make sure that the lugs are not spinning inside the hub?
anyhow, i'd recomend a drill with a "spinning top" looking bit, drill into the lug nut and you'll be able to crack it off.
the "top" bit im talking about sorta looks like a dredel that you can spin, except as u keep drilling it widens up so it'll eventually break off the lug nut.
speeddreamz is offline
Old 12-21-2004, 03:33 PM   #27
the head
the head's Avatar
the head is making a name for him/her selfthe head is making a name for him/her self
if the thing keeps breaking more you should be able to split it go get a good cold forged chisel that will fit down into the recess then line it up on the nut and beat the thing with a hammer it will slowly work its way into the nut until it splits
I never knew you could do that with an eggplant
the head is offline
Old 05-17-2005, 02:41 PM   #28
snp_ethan
snp_ethan is an unknown quantity at this point
Send a message via AIM to snp_ethan
mm well. after reading all this I just came to one conclusion:
NO ONE HAS A FREAKING IDEA OF WHAT TO DO, SO IMMA START A THREAD on HOW TO REMOVE THE WHOLE WHEEL, and WORK on it from the inside...
snp_ethan is offline
Old 05-17-2005, 03:24 PM   #29
originalsin
originalsin has a little shameless behavior in the past
drill it out.... thats wat u hada do
and i bought gorilla tuner lugs, gotta stick with a name brand
as for tq, buy a torque stick for nissan lugs, i got one its great, u can use an impact and not over tighten the lugs, the metal is made to liek flex at a specific tq
originalsin is offline
Old 05-17-2005, 03:56 PM   #30
S14DB
AFC #1
S14DB's Avatar
That would be better than BUMPING A 6 MONTH OLD THREAD!!!
S14DB is offline
