Old 12-23-2004, 06:42 PM   #1
chuy
chuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura about
Tanabe Sway-Bars S14
So I read several posts from the search engine and I noticed that there were not that many posts about the Drift Spec 30mm front and I think 27mm for the rear. I own the base model S-14 so Im also looking at what mounts I need for the front and rear. I know that there isnt any mounting equipment in the rear and if possable Id like to upgrade the front mounting equipment, bushing stuff. Any help would be welcomed.
Slide Happy
chuy is offline   Reply With Quote
Old 12-23-2004, 06:53 PM   #2
Dousan_PG
Dousan_PG's Avatar
get them! they rule
i only have the rear because i like stock front but if you dont have anything, s13 brackets and peices work on it too. same stuff, my friend did that on his, oh and i did that on mine, used my s13 stuff
front you can get new bushings in the brackets (energy suspensions) and the endlinks, new would be $$$ but ususally the stock ends are a-ok
edit: i forgot
tanabe gives youits own bushings when you buy it. because the bar is thick you cant use the stock ones anmore. so for rear, yo uneed new u brackets bolts and endlinks (with bushings)
Aaron
Pink GodziRa
Old 12-29-2004, 01:36 AM   #3
Twinturbozs
Twinturbozs is a well-known jackass
so the stock U brackets wont fit in the rear using the 27mm tanabe bar?
Twinturbozs is offline   Reply With Quote
Old 12-29-2004, 09:15 PM   #4
chuy
I picked them up today I was very happy with the way they look and feel, I got the base model so Im just going to order all the mounting hard ware so I dont have to worry about saving bolts and stripped bolts. Im thinking about getting solid end links from SPL Im awaiting an e-mail from them.
Slide Happy
Old 12-30-2004, 12:09 AM   #5
Dousan_PG
Dousan_PG's Avatar
no stock u-brackets fit
its the bushings that dont
but tanabe supplies those so no worries
spl is on vacation, so theyll reply when they get back, pls be patient, just fyi!
Aaron
Pink GodziRa
