Old 01-05-2005, 01:03 PM   #1
Twinkie
Twinkie is an unknown quantity at this point
Send a message via AIM to Twinkie
Electric Fan for the Koyo Radiator
Hey all. I was wondering what size electric fan most of you use for your koyo radiators. And how much cfm's are you running. (how many cfm's would be good to cool an SR?) Also, what works better for you? Puller fan? or Pusher fan?
Twinkie is offline   Reply With Quote
Old 01-05-2005, 03:48 PM   #2
msaskin
msaskin is an unknown quantity at this point
Send a message via AIM to msaskin
Stock mechanical fan & shroud. Never had any overheating problems, and that includes a half dozen track events (2+ hours of track time at each event) in the 110+ degree california/nevada summers.
~matt
it's not turbo lag...it's foreplay
'01 Ford Excursion Limited.
Powerstroke Diesel
Coming in spring: ???
msaskin is offline   Reply With Quote
Old 01-05-2005, 07:37 PM   #3
ace240sx
ace240sx is an unknown quantity at this point
The stock shroud also completes the engine bay, you can notice this void on 90% of sr swaps. Only go with some electric fans if you drop some sort of nissan inline 6 motor...
"we endorse beating kids faces in as soon as probation is over and we relocate back to so cal"
ace240sx is offline   Reply With Quote
Old 01-05-2005, 07:44 PM   #4
FRpilot
FRpilot's Avatar
yes. most sr swaps i see dont utilize the shroud and clutch fan.. a pain to put in?
FRpilot is offline   Reply With Quote
Old 01-05-2005, 08:15 PM   #5
msaskin
Not at all. The stock e-fan and shroud fit like stock. The fan sits a bit closer to the shroud, but there are no clearance issues provided you properly secure the shroud to the radiator (like it's supposed to be)
~matt
Powerstroke Diesel
Old 01-05-2005, 08:58 PM   #6
TheTimanator
TheTimanator's Avatar
Flex-a-Lite Dual 12in.
Thats what I have. Fits really snug. Had to trim it slightly but it was an easy fit.
There are a few reasons people go with the e-fans.
Some people want control..so they can leave the fans running at all time or have an adjustable thermostat.
They don't want there car to sound like a truck.
Some people think it will cool better.
I got e-fans b/c I didn't have a shroud.
Old 01-05-2005, 10:09 PM   #7
Suk02Si
Suk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfectionSuk02Si is close to perfection
I heard '95 Altima's come with dual electric fans that work with the Koyo.
Suk02Si is offline   Reply With Quote
Old 01-06-2005, 02:40 AM   #8
mike2016
mike2016 will become famous soon enoughmike2016 will become famous soon enoughmike2016 will become famous soon enoughmike2016 will become famous soon enoughmike2016 will become famous soon enough
keep the stock fans and shroud, or OEM electric fans from other cars. I had the Flex a lite 210 fans and they sucked, overheating with a/c on, and overheating on the track under 105F degree summer. it's so loud but dont pull that much of air. this is with koyo rad.
mike2016 is offline   Reply With Quote
Old 01-07-2005, 12:33 AM   #9
Twinkie
so you guys are saying a 14" fan is too big for the koyo? because i was about to purchase one soon. i surrently dont have a shroud right now or else i woudltn need to worry but too bad when i purchased my sr20, it didnt come witht he shroud. it wouldve savced me some money. i dont have any broblems with overheating, but i still want my engine cooled to the max.
Old 01-07-2005, 09:10 AM   #10
s14 blacktop
s14 blacktop is an unknown quantity at this point
Send a message via AIM to s14 blacktop Send a message via MSN to s14 blacktop Send a message via Yahoo to s14 blacktop
The reason I CHOSE to go with electrical fans is to reduce parasitic loss, I used my KA ac fan and the SR fan side by side never had a problem with them, I set mine on high and hooked them to the ignition so every time the car stars the fans stars. If you cant find the fans that go on there go to autozone they have 12" fans that are universal they run @ 60 dollars a piece.
but if you could get the 14" one get it more flow = more cooling..
I'm here to inform not to conform...
s14 blacktop is offline   Reply With Quote
Old 01-07-2005, 07:05 PM   #11
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Or dual Altima fans will fit, just have to trim the edge a bit.
Old 01-07-2005, 10:08 PM   #12
msaskin
Originally Posted by evrae205b
im also geting a koyo radiator and wonder what would be the best fan setup. (not worried about cheapest). i need a very efficent setup to help with a sr20redtop setup i plan to use for track purposes only. my cars power goals are going to be around 400-450rwhp so i need sufficent equipment to maintain cooling on those goals. nothing but the best you know.
stick with the stock fan & shroud. As said above, my car was fine making 380rwhp with a Koyo, Water + Water Wetter (no coolant), Stock mech. fan and shroud (actually, I only used the top 1/2 of the shroud)
~matt
Powerstroke Diesel
Old 01-08-2005, 12:36 AM   #13
Twinkie
~matt
yeah but like i said, i bought the sr20 with out the fan shroud therefore i wanna get an electrical fan to get the maximum flow and CFM but i dunno how much of it is enough. I was contemplating about getting a 14" push/pull elect. fan with 2610 CFM's ($90). but i dunno if thats way more than enough or if that much cfm's is necisarry as opposed to a cheaper 14" that pushes/pulls about 1210 CFM's($40).
