Right hand drive
I was curious if anyone has ever looked into or tried to convert from left to right hand drive in the s13. If I bought the front clip, would I have what I need to do the swap?
![]() Join Date: Oct 2004
Dont try it unless you have at least half of the car(half meaning not the front clip but also the 3 feet of where the chair goes back, the weld job alone is going to cost $2000 for prof welder, depending on how fast he works will determine how much you gotta shell out, On the weld you dont want to go cheap, Oh yeah did I mention it was illegal....
you would need to splice the wires, too much work ..... take it from me I tried to do it on my s14, just swap motor its way easier... I thought just weld the front onto my car and thats it, the wires that go to the back of the car are the biggest pain to work with I tried to change it but could not get the wires correct since theres a double of every color 3 days into it I gave up on it and switched it back to us ver..(I played with it to see if it would work and it didnt so no go)... Dont waste your time or your money on this unless you are a profeassional welder, and you know exactly where every wire goes to the back( I mean if you could distinguish 5 blue wires from 4 blue wires, with out taking the whole harness out and following every wire..)
I'm here to inform not to conform... ![]() ![]() |
#3 | |
are you saying your tried to weld a front clip to your 240?!?!?! |
![]() Join Date: Aug 2003
or you could always make a new fire wall.
some people dont always weld the clip onto the 240sx, me personally wouldent go that route...if using it for spirited driving and all.
#5 |
![]() Join Date: Mar 2003
![]() ![]() ![]() ![]() Feedback Score: 1 reviews
you could get one of those kits that mail people put in thier vehicle to deliver mail. just a thought.... a pretty dumb thought..... but its still an idea.
#6 |
No I implied I researched it about the welding, and I tried to reconfigure my existing B1 harness to mach the E101 SR harness, to see if it would work..
#8 |
![]() Join Date: Mar 2002
RHD is not illegal, and you dont weld the clip to the front of the car, just swap parts and edit the firewall.
sentinelguild.com/nzo/PFCDB/ |
#9 |
rocksco on FreshAlloy did it to his Kouki S14. A woman in a Mustang later crashed into his car.
He had a very in depth post on what he did to do it. He did not weld a halfcut to his car or anything, IIRC. He just drilled new holes and swapped shit. |
#13 |
I wanted to do this conversion mostly for the experience and for some stupid reason, RHD cars fascinate me. I was think more along the lines of swapping parts and modifying firewall rather than welding a half-cut. If I were going to do that then I might as well get the JDM cuz the VINs would be different anyway.
#15 | ||
![]() Feedback Score: 9 reviews
Kthxbye
#17 |
Well this was a misunderstanding I though you was assking if you could swap the front clip, oh well its still too much time and money for what cuz your on the right hand side, if your that crazy over RHD, import a 180sx from japan and dont use it on public roads.
I'm not shure anymore either, a mechanic in houston told it was legal to import a RHD but not to switch it, even the guy I got the clip from said it might be illegal, and then This guy I know told me what happened to him so I assumed it was illegal... I dont know anymore..it might have something to do with the state inspection!!!
#18 |
![]() Join Date: Nov 2003
Can't speak for CA, although NY is prolly the second most anal state in this country, and it's 100% legal to have RHD vehicles here. I'm not positive, but my guess is that if your friend got his car impounded, it's because they thought that it was not a legal US vehicle, not cause RHD is illegal, but like I said, that's NY law, now CA law, I can't speak for sure about where all you are.
Nissan lover in waiting |
#19 | |
This guy...
![]() Join Date: Feb 2003
Swapping a dash is going to have it difficulties much like anyother project, but that makes it worth it. Ill take some pictures of my bare firewall so you can see what you are getting into. You will have to swap the Brakle M/C, throttle linkage, pedals, JDM Rack (eye think...), dashboard. To complicate things more add A/C and heating...
My project car... From dust you were born, And to the ashes you return ~ Kill Switch Engage Family Guy Quagmire: Hey, how old are you sweet thang? Connie: 16. Quagmire: 18? Alllll-right! Connie: Mommmm! Quagmire: I like where this is going, Giggidy giggidy gig-gi-dy! |
#20 |
RHD is not illegal in USA. The worst way to do it is by welding the pillers. The best way to do the swap is by drilling out the spot welds on the firewall and spot weld it back into the OEM position and do a complete 16 point measurements. Once that is done, you use the complete RHD engine harness, dash harness, but keep your interior harness but swap them (left to right, right to left, etc.). You also need to move your trunk/gas latch over. Everything else from front clip should bolt right in. Don't forget to get RHD seats and door panels (or power switch). The driver seats sits lower. maybe it's the rails. In USA, you drive on the right side of the road; so by using the JDM(RHD) headlights, you'll be blinding on coming traffic because of the cutoff. So use USDM headlights. I see so many idiots using JDM headlight housing and don't understand what cut-off is.
I'm not talking from experence. I do automotive body work and this is what I think would be done. Furthermore, if you're going to attempt a RHD convertion, spend the time to do it correctly the first time. There has only been a few people doing this convertion correctly. First person is Jay smith's Integra RS. IMO, why the hell would you do this. It's a waste of time and dumb. You'll just get more blind spots and it's not fun for a daily driver -friends have RHD cars. If I wanted a RHD car, I would much rather import one myself and do a vin swap ![]() The cops won't know if it's a convertion =D FYI, JDM RHD cars don't have the DOT aproved impact brace on the doors Micky Mouse RHD convertion: http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg Thread: http://www.honda-tech.com/zerothread?id=1072221
![]() driftingisgay.com Last edited by nrg; 01-08-2005 at 12:59 AM.. |
#22 |
RHD is perfectly legal, Bringing in a RHD Silvis or 180SX now thats illegal.
You only need to swap out the fire wall for the body. but you will need the steering parts etc etc etc for RHD. First RHD swap was a honda? HA!!! VW guys have been doing RHD swaps for years. The first bug i saw right hand drive had to in like 1983 when i was 5 years old. My neighbor did conversions in his drive way for extra cash, he told me about Australia and thier krazy karz and kangaroo burgers!!! Max |
#24 |
no. first person that i've known that did the convertion "correctly" is Jay smith's car. He paid a butt load to get it done too.
He's not the first person that DID the convertion.
![]() driftingisgay.com |
#25 |
![]() Join Date: Dec 2003
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 27 reviews
rhd conversion
i succesfully did the rhd conversion for any 1 that has questions email me at [email protected] and heres a few pics of it completed but i do have pics of the firewall swap http://www.cardomain.com/memberpage/725558/2 check it email for questions
#26 |
![]() Join Date: May 2003
i'm currently in the process of doing the swap. A friend of mine baught a front clip, i swapped the motor and got the clip and goodies as payment. I've been at it for countless hours now, the clip is finally in peices, like they would have come off the assembley line to be wleded on. I just baught a few spot weld drills. Like it was mentioned before it may be the hardest way, but the panels line up perfectly because of the way a proper spotweld drill works. It works like a hole-saw and leaves the centre of the weld intact as a guide for placement of the pannel.
The only real problems i've run into this far follow: The wiper arms are reversed and the peice that is welded to the firewall where it's located has the stock vin AND the windsheild seems to be attached to this. Now i don't know if i should remove MY windsheild and risk cracking it, and replace the whole peice with the JDM peice and weld the stock vin on. the other problem now lies with the steering coloumn on the right hand side, the supercharger setup we were working on has clearance issues....tradeoffs i guess... It's not really that hard to do, it's just extremely time consuming...and to do it right bracing needs to be added temperarorly to keep the body in shape until the new structure is welded in. i'll post pics up in a week or two when i'm not so busy. |
#27 |
rhd conversion
hello people! i just bought a s14 front clip with the sr20det,and rhd
![]() ![]() ![]() ![]() Last edited by tonyaccord; 10-21-2005 at 07:30 PM.. Reason: for got my e-mail |
#28 | ||
Read the thread! It has the answers you seek. Passage of time doesn't make the facts any different. And to hell with emailing you.
#29 |
![]() True that dude :hammer: but i figured that one of you guys would have maybe discoverd something?
