Old 01-08-2005, 03:04 PM   #1
WILDACEX187
WILDACEX187's Avatar
WILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond repute
Send a message via AIM to WILDACEX187
power locks (searched and no help)
well its time to put an alarm on my car but i gotta get the power door locks to work right. usually when u're inside the car and u lock the driver door the passenger should lock, same thing if u unlock it. well when i do this in my car all i hear on the passenger side is a click but the lock doesnt move. BUT if i unlock the car with the key from the passenger side (driver side only opens driver side not both ) it opens both
how do i get it to open both when i unlock the driver side door and when i lock the driver side door? all i hear is a click inside the passenger door when i try it. thanx for any help that u guys can give me
SR POWA COUPE LUVVV!!!
WILDACEX187 is offline   Reply With Quote
Old 01-08-2005, 03:15 PM   #2
FRpilot
FRpilot's Avatar
i am having trouble with the power door locks too. right now, my alarm is connected to everything except the pdl..
FRpilot is offline   Reply With Quote
Old 01-08-2005, 03:20 PM   #3
Ritz S14
Ritz S14's Avatar
Sometimes the actuator becomes loose. So when it locks unlocks it doesn't "grab" the linkage to unlook the door. You'll have remove the door panel and take a look.
Ritz S14 is offline   Reply With Quote
Old 01-09-2005, 02:39 AM   #4
WILDACEX187
but then why does the passenger side open the driver side
i gotta wait till it gets warmer. its 32 ova here
Old 01-09-2005, 12:29 PM   #5
projectRDM
projectRDM's Avatar
What year is the car? 89-90 cars use a 2-wire system with a trigger in the keyswitch and the driver's actuator. 91-94 cars use a single wire system that's a little different. It would sound like one of the sneding units is loose/damaged if it's only working one way. Pull the panels and inspect both units, follow the FSM to verify their operation.
FORMERLY R240NA
Old 01-09-2005, 01:38 PM   #6
WILDACEX187
its a 91. should i inspect the actuator or the wire?
