Old 01-09-2005, 12:54 AM   #1
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
cheapest way to get Z32 calipers
so i've already invested a ton of money on brake parts, and 300zx wheels, and tires, and spacers, and a lot of other goodies. i still havent bought the z32 calipers that i want....
this is what i want. *a rebuilt oem caliper 30mm or
*a rebuilt and powdercoated/painted
does anyone know where to get the full rebuilt z32 30mm calipers. for the front.
thanx in advance
CoasTek240 is offline   Reply With Quote
Old 01-09-2005, 01:05 AM   #2
Ritz S14
Ritz S14's Avatar
Calipers/lines/pads/rotors/brake fluid will run you about $300
I did a write up on this... Piecing it myself. But if you buy them all at once at a junkyard you'll save a ton of money. But not everyone has the liberty and luck to find a z32 at the wrecking yard with good parts in tact.
Ritz S14 is offline   Reply With Quote
Old 01-09-2005, 10:58 AM   #3
SirWarrior
SirWarrior is an unknown quantity at this point
I was one of the lucky ones that found a 90 NA Z32 and got the whole suspension/pumpkin/MAF/Brake MC and wheels with good rubber for mere $400
But if you look in Autozone, they got reman Z calipers for 55Each plus core. That was what I was planning on doing untill I came accross the Z in the yard.
92 FastBack - Project
98 SE - Daily Driver
SirWarrior is offline   Reply With Quote
Old 01-10-2005, 12:22 AM   #4
CoasTek240
CoasTek240's Avatar
so, if i could just find a cheap set of z calipers, i can buy remanufactured ones at an auto parts store, and then i would need to paint them or get them powdercoated....
i may do that. are there any other suggestions?
Old 01-10-2005, 01:03 AM   #5
OptionZero
OptionZero's Avatar
If your local store is particularly stupid, you might be able to turn in your 240sx calipers as the core instead of getting 3Z ones.
OptionZero is offline   Reply With Quote
Old 01-10-2005, 10:36 AM   #6
CoasTek240
CoasTek240's Avatar
yeah, i had heard about this. I might give that a try.
If i can find a fully built remanufactured caliper, then i suppose i could paint them myself.
looks like ill have to go with this method, if no one else comes up with anything else.
Old 01-10-2005, 03:31 PM   #7
kouki2g0
kouki2g0 is an unknown quantity at this point
http://www.zilvia.net/f/showthread.p...311#post595311
this is where i got mine
kouki2g0 is offline   Reply With Quote
