Old 01-15-2005, 01:03 PM   #1
gorgasm
gorgasm's Avatar
gorgasm is just really nicegorgasm is just really nicegorgasm is just really nicegorgasm is just really nicegorgasm is just really nicegorgasm is just really nicegorgasm is just really nicegorgasm is just really nice
Send a message via AIM to gorgasm
Lowest Spring Drop?
Im using some Cusco coilovers at the moment and they are far too stiff for what I use the car for... So I think im going to replace them with some aftermarket shocks and springs, however I want something thats going to give a good drop.. The lowest ive found were the tein stechs which were something like 1.0 in front 1.4 in the rear. I was wondering which spring has the most aggressive drop.. yes ive searched and came up with nothing... so any input will help alot, thanks
gorgasm is offline   Reply With Quote
Old 01-15-2005, 05:52 PM   #2
gorgasm
gorgasm's Avatar
anyone?
this message is too short blah blah blah.
Old 01-15-2005, 06:24 PM   #3
S14DB
AFC #1
S14DB's Avatar
A low drop is going to ride worse than coilovers.
Old 01-15-2005, 06:31 PM   #4
NotDave
NotDave is an unknown quantity at this point
sportline
NotDave is offline   Reply With Quote
Old 01-16-2005, 12:09 AM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Tanabe springs are the lowest springs ive seen...atleast on a S14.
Old 01-16-2005, 01:01 AM   #6
gorgasm
gorgasm's Avatar
sportlines? cool... tanabe, i havent seen those for sale.. know of anywhere that sells them? what kind of price range on those?
Old 01-16-2005, 01:56 AM   #7
s0ldats
s0ldats is on the path to ruins0ldats is on the path to ruin
i don't know how gay the front geometry on s14's are but if they're similar to 13's you'll be humping the front bumpstop before you go low enough.
cuscos too stiff for whta the car is used for? downgrading to spring/shock? wtf.. is it used to pose?
s0ldats is offline   Reply With Quote
Old 01-16-2005, 04:30 AM   #8
Twinkie
Twinkie is an unknown quantity at this point
Send a message via AIM to Twinkie
go with coilover damper kits. you can have any height you want with adjustable damper for racing and street use. your best off with it. I cant really tell you which is best, but do the research on which would be best for you (personal preference thing). if a set of coilover/adjustable damper kits are too expensive for you, and your planning on sticking with aftermarket shocks/springs, mine as well get the Tein Basics atleast (although they arent the best comfort) but they are pretty cheap (if ~ $800 is is an ok price for you) and very decent and as i heard better than teh regular shocks/spring set up .
Tein basics is basically shocks/springs set up except you can adjust the height with out the cheap ass drop zone or whatever cheaply made generic brands.
Twinkie is offline   Reply With Quote
Old 01-16-2005, 12:30 PM   #9
gorgasm
gorgasm's Avatar
I see... And the basics still have good/decent ride quality? thats my main concern right now since i have to drive this car for long periods sometimes.. thanks alot for the help i appreciate it.
Old 01-16-2005, 04:13 PM   #10
Twinkie
I heard the Tein Basics ride is jsut OK. not too bad but not that good. A lot of people say it feel equivalant to eibach sportlines w/ kyb agx. But at least the tein basics are height adjustable.
and yeah...the only problem is the teins dont come with pillow mounts for both upper and rear, so your camber will be a little off. but you can buy them seperately. youll be able to find them for about $100 a pair. Also, the dampers arent adjustable.
if you are interested in some that come with these that are also cheap, look into d2 coilovers or k sports. but i heard the quality isnt so good. I beleive megan racing coilovers do the job very well, even better than d2's and ksports. these 3 coilovers may run ~ $750 - $900. (people in the Megan Racing coilover thread say that it is VERY worth the money.)
Old 01-16-2005, 04:58 AM   #11
Shin_Kudo
Shin_Kudo is an unknown quantity at this point
If you're just after the drop, Tein SS or FLEX might do the trick, as well.
'95 240SX Base Pearl White
Shin_Kudo is offline   Reply With Quote
Old 01-16-2005, 02:37 PM   #12
tew photy
tew photy is making a name for him/her selftew photy is making a name for him/her self
basics are alright, but they do not have any upper pillowball mounts/camber plates, so that will not be adjustable. if you are going after coilovers for under 1000, maybe check out the D2s? ive seen them for like 750 shipped, and they come with the camber plates. there was a discussion about them on here recently, try searching for that
tew photy is offline   Reply With Quote
Old 01-16-2005, 09:16 PM   #13
rainier
rainier's Avatar
rainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud of
Send a message via AIM to rainier
jus get some eibach sportlines. when i had my s14 the drop was pretty low. no one believed they were sportlines but yeah. the drop is F*cking low. good luck with your lip. if you have one.
rainier is offline   Reply With Quote
Old 01-16-2005, 11:11 PM   #14
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
if you JUST want the drop...i suggest D2 w/ soft springs
if you want high quality, look into something "jdm"...i hear KTS is all the rage as of lately for about 1200 bucks
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 01-17-2005, 12:17 AM   #15
gorgasm
gorgasm's Avatar
hmm thanks for all the input guys..... Im gonna try putting some 6/4 springs on the cusco coilovers I have on there now.... you think that will make a big difference? or should I just save my time and go for the tein basics? I believe the springs are something like 8/6 on there now.... Just wondering how big a difference some softer springs will make?
Old 01-17-2005, 02:50 AM   #16
DocTaDrifT
DocTaDrifT's Avatar
DocTaDrifT is an unknown quantity at this point
Send a message via ICQ to DocTaDrifT Send a message via AIM to DocTaDrifT
thumbs up on the sportlines not too low not too high
DocTaDrifT is offline   Reply With Quote
Old 01-17-2005, 07:45 AM   #17
publicenemy137
publicenemy137's Avatar
publicenemy137 is an unknown quantity at this point
Send a message via AIM to publicenemy137
yea sportlines r nice, but you will have a tad fender gap up front.
check out my 240sx in my cardomain page
1
CLICK HERE TO SEE MY CARDOMAIN!
help me decide my next set of rims
publicenemy137 is offline   Reply With Quote
