Old 01-24-2005, 02:40 PM   #1
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
New Features for Nissan Datascan
If you havent bought this for your ka24de or sr20det 240 yet here's more reasons why you should. Get a Conzult box and get this software!! This comes from Plms development in Australia and its only $25 AU dollars. New updates to v1.4.
Bug fixes and changes:
Speed Trial result now in seconds (previously in 10ths of second)
Minor cosmetic and label changes
Bug fix for Air Flow right hand reading
Improved Rom Download algorithm for better reliability (slow option only)
New functions:
Tyre size speed correction (Preferences window)
Auto connect to ECU (Communication window)
Compatibility with 96 model z32 ECU (Communication window)
Active test for IACV valve
User definable 0 to xxx Speed Trial
Live register test – discovers parameters supported by the ECU as not every ECU supports them all, for example: Intake Air Temperature (Setup window)
Map trace – a real time trace of a position on the map. This function is only available for z32 300zx cars at the moment. If the real time TP value address is known the function can be set up to work on any Consult I Nissan car.
http://www.plmsdevelopments.com/consult_if.htm
Also im curious if anyone has done a Carputer yet for their vehicles as I will be assembling one soon.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 01-24-2005, 05:23 PM   #2
S14DB
AFC #1
S14DB's Avatar
I don't see the KA listed.
Old 01-24-2005, 05:54 PM   #3
brianglawson
brianglawson's Avatar
brianglawson is an unknown quantity at this point
Send a message via ICQ to brianglawson Send a message via AIM to brianglawson Send a message via Yahoo to brianglawson
now what is this....like a car consultant?
S15 SR20DET Powered, Kouki S14 http://zilvia.net/f/showthread.php?t=578575
brianglawson is offline   Reply With Quote
Old 01-25-2005, 11:03 AM   #4
sr240mike
Click on the link and you will receive answers. I've used it on ka's and it worked, just not the sohc because they do not support the consult protocol.
Old 04-12-2006, 03:44 PM   #5
JohnC
JohnC's Avatar
JohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of lightJohnC is a glorious beacon of light
FYI
Nissan DataScan 1.5 is out.
Well worth the small fee to get all this info
from the ECU. Highly recommended.
John
JY Racing LTD.
JohnC is offline   Reply With Quote
Old 04-12-2006, 04:13 PM   #6
alexchanman
alexchanman is making a name for him/her selfalexchanman is making a name for him/her self
Send a message via AIM to alexchanman
no workie for the ca18det???
alexchanman is offline   Reply With Quote
Old 04-13-2006, 09:32 AM   #7
SHIFTrl240
SHIFTrl240's Avatar
SHIFTrl240 is an unknown quantity at this point
nope, no ca18
SHIFTrl240 is offline   Reply With Quote
