Old 01-24-2005, 10:11 PM   #1
makoto
makoto's Avatar
makoto is an unknown quantity at this point
Send a message via AIM to makoto
ka24de head gasket faq
what size allen do you need to remove the headbolt studs?
makoto is offline   Reply With Quote
Old 01-24-2005, 10:15 PM   #2
s13irdie2
s13irdie2 is on a distinguished road
im pretty sure its a 10.
1990 s13
IslandMotorsports, Inc.
s13irdie2 is offline   Reply With Quote
Old 01-24-2005, 10:22 PM   #3
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
Yes, 10mm...buy a 3/8" socket with a 10mm allen wrench head from sears, maybe $7.
If you use a 1/2" drive socket, or one with a larger O.D., it may not fit down the hole for a couple bolts...FYI.
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 01-24-2005, 11:08 PM   #4
s13irdie2
an extension would help. i jsut used the allen wrench head with a 3/8 socket and used the boy from the jack as an extension.
1990 s13
