Old 01-26-2005, 08:52 AM   #1
HATchTRICK
HATchTRICK's Avatar
HATchTRICK is an unknown quantity at this point
Turbo Selection.
Is this turbo a good choice a S14 sr. The motor is basically stock with 3" exhaust, z32MAF, 740cc injectors, greddy intake manifold, power fc, and top mount manifold. I am looking to go for 400HP for now then over next winter build the motor and go for over 500hp. Should i go with this Turbo or just get the t3/t67 now and end the questioning?
COMPRESSOR SPECS:T04S
flow: 61 lbs/min 781cfm
.70 A/R housing
60-1 TRIM wheel
TURBINE SPECS:T3
.48 A/R housing
HIGH FLOW 76 TRIM stg 3 wheel
oil lubricated centersection.
due to large compressor flow internal wastegate option is not available.
COMES STANDARD WITH 360 DEGREE THRUST BEARING!!
HATchTRICK is offline   Reply With Quote
