Old 02-04-2005, 05:36 PM   #1
DTS
DTS is a well-known jackass
Serious problem with my subframe (Pics)
So im trying to install my SPL parts aluminum subframe spacers and i do the passanger side no problem, on to the drivers side, and the front subframe mount wont drop down enough for me to slide the spacer in
so i look at it and the actual bolt on the end of the peg is connected to the rubber bushing but the passanger side is fine!
As you can see in this pic this is the passanger side which is fine and has a rubber ring and has a bolt that drops threw the ring
on the drivers side the bolt is actually connected solidly to the bushing not allowing the subframe to drop!!
what the hell is going on guy!!
will it affect my performance if i only use the bottom half of the spacers for the front mount the back is fine and the passanger!
please help
DTS is offline   Reply With Quote
