![]() Join Date: Jan 2002
![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
ok, here is my situation.
-check engine light on -running rich -rough idle -LOUD BANGING noise from #1 cyclinder(loud) as if there is chain slap!! help me please
240SXONE www.240SXMOTORING.com --- One Stop Shop for Your Nissan 240sx ![]() ![]() |
![]() Join Date: Sep 2001
with the engine still running (i assume it still runs), don't rev it up, pull the #1 spark plug wire out (loosen it b4 you start the engine, leave it all the way down in the hole) using a rubber handled pliers or something (so you don't zap urself with the ignition spark <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/butbut.gif" border="0" valign="absmiddle" alt=':but:'>
![]() if it's more of a "slapping" noise, i suppose it could be the timing chain prob that these cars have... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/huh.gif" border="0" valign="absmiddle" alt=':huh:'>. good luck!
'98 240SX 5spd[br]http://www.speedwisemotorsports.com |
that could be the cause for this but remeber that i had the motor rebuilt and i just got it running last week. it has less than 100 miles on it. maybe it could be the timing.
i got another question, its a dumb one but it just popped up in my head.
suppose if i put the distributor in backwards(meaning that the when the #1 cyclinder is suppose to fire, the #4 cyclinder is actually firing) wouldnt the car not even run?/ pplus, could it be the knock sensor, i had a hard time trying to put the connector on, ,maybe thats why i am getting check engine light? and with bad timing it could run like shit. i dunno, tonight i am going to check everything, so please give me suggestions
#5 |
![]() Join Date: Jun 2001
Have you checked the code your computer's throwing? That may help a bit to see what's causing the CEL to come on, which may determine what's wrong w/ your engine.
Lauren '91 300ZX TT Ultra Red 5-speed - JWT POPCharger, JUN flywheel, ACT clutch, Energy Suspension Bushings, Tokico Blues - dyno'ed 295hp/306tq '94 300ZX TT Black Emerald Pearl 5-speed - JWT POPCharger, JWT ECU w/ Stillen chip, Stillen exhaust, Tokico Blues, Eibach ProKits, 18" Enkei RP-01 wheels - dyno'ed 333hp/385tq '00 WS6 Trans Am Bright Red 6-speedFOR SALE - only 29k miles, stock, fully loaded, only $23,999 (NADA $26300) Green Country Motorsports Northeastern Oklahoma SCCA |
#6 |
Take your oil filter off and saw it in half and look for metal shavings also drain the oil and put a magnet in the oil to also search for metal shavings.If that comes out negative take the plug out and see if the elactrode is gone. Now if everything comes out fine drop your oil pan and check the crank cuz you might of spun a bearing on it. Did you use clevite bearings?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
Norbert 91 Eclipse GSX 96 240 SE KA-T http://www.PhatKA-T.com http://www.Sound-Performance.com |
#7 |
Will never get banned...
knock snesors dont trip engine lights which is very weird. trust me i work at nissan and all the techs even say so. i dont know why and the techs said something but i forgot what it was. i know they couldnt explain it correctly though
-=-99 Sentra SE 5 speed-=- -=-95 240 SE 5 speed-=- |
