Old 02-11-2005, 11:07 PM   #1
TK
TK is an unknown quantity at this point
FS - Boston Sub woofer Alpine Amp SOCAL
Well, i didn't think i would ever sell this but here it is. It's a Boston Acoustics C110 sub box premade by Boston. Comes with 1 10" Competitor sub and passive radiator (secondary sub), it is pretty much 2 subs in a single box and hits VERY CLEAN. Box is made of MDF and very compact. here are the specs:
Nominal Size
Single 10" Competitor
Recommended Amplifier Power
50-850 watts
Nominal Impedance
2 ohms
Width
12 3/16" (310mm)
Depth
12 3/16" (310mm)
Height
11 1/4" (286mm)
Passive Radiator
Tuned Single Rear-Firing 10"
Box retails for $399 and i'm asking for half the cost so $200 obo
pics of the sub
rear passive radiator
connections- banana plug or wire fed
Alpine 5 channel amp
5/4/3 Channel Power Amplifier
Features
General-Amplifiers
Bass Engine Ready
Adjustable Crossover (HP/LP)
Input Channel Selector
Input Mode Selector Switch
One side Terminal Layout
Speaker Level Inputs
Gold Plated Insert Power Terminals
Noise Elimination Coil
5/4/3 Channel Operation
MOSFET Power Supply
DC-DC PWM Power Supply
Discrete Pre-Amp Stage
DC Straight Design
STAR Circuitry
Solid Copper Bus Bars
MultiMode
Top Mounted LED Power Indicator
Specifications
MAX Power (at 14.4V,EIAJ)
Per channel into 4 ohms- 90W x 4 + 300W x 1
Bridged 4 ohms- 240W x 2 + 300W x 1
RMS Power (at 12V,20Hz-20kHz)
Per channel into 4 ohms- 30W x 4 (0.08% THD) + 100W (0.3% THD)
Per channel into 2 ohms- 40W x 4 (0.3% THD) + 100W (0.3% THD)
Bridged 4 ohms- 80W x 2 (0.3% THD) + 100W (0.3% THD)
RMS Power (at 14.4V,20Hz-20kHz)
Per channel into 4 ohms- 50W x 4 + 150W x 1
Per channel into 2 ohms- 60W x 2 + 150W x 1
Bridged 4 ohms- 120W x 2 + 150W x 1
General-Amplifiers
Heat Sink (WxHxD)in- 15-5/8O x 10-1/4O x 2-3/8O
Foot Print (WxHxD)in- 15-5/8O x 11O x 2-3/8O
Slew Factor- greater than 5
Input Impedance- 10k ohm
Speaker Impedance- 4 or 2 ohms(stereo), 4 ohms(bridged)
Dividing Network- 50Hz-200Hz HP/LP (12dB/oct)
Heat Sink (WxHxD)mm- 270mm x 260mm x 60mm
Foot Print (WxHxD)mm- 460mm x 280mm x 60mm
Weight-
Frequency Reponse- 10Hz - 50kHz (+0, - 1dB)
Signal to Noise (S/N)- 100dBA (referenced to rated power)
paid $450 will sell for $200 obo
both items used for about a year and have been in storage for the past year
TK is offline   Reply With Quote
