Old 02-16-2005, 07:26 PM   #1
sj250
sj250's Avatar
sj250 is an unknown quantity at this point
Battery setting off alarm!!!???
I left my dome light on the other night and my battery went dead. We pulled the cables off the battery and charged it back up but now whenever I reconnect the battery cables the factory alarm goes off and the lights start flashing. Basically it is like someone is pushing the panic button everytime I try to hook up the battery. Any ideas? It's getting very annoying.
sj250 is offline   Reply With Quote
Old 02-16-2005, 07:41 PM   #2
Ritz S14
Ritz S14's Avatar
It may not have a factory alarm?
If anything. Connect the battery terminals, and run to the driverside door and lock then unlock the door. If that doesn't reset it. You have an aftermarket alarm..which in that case pull the fuse, and disconnect the alarm.
Ritz S14 is offline   Reply With Quote
Old 02-16-2005, 07:49 PM   #3
sj250
sj250's Avatar
It is the factory alarm and there is no additional alarm.
Old 02-16-2005, 08:14 PM   #4
projectRDM
projectRDM's Avatar
The OE alarm does not go off when power is lost. And if by some reason yours does, a flick of the key in any cylinder will turn it off. If not, it's not OE.
FORMERLY R240NA
Old 02-16-2005, 11:27 PM   #5
sj250
sj250's Avatar
Thanks for the tip, that worked perfectly and the car fired right up.
Old 02-17-2005, 12:10 PM   #6
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
mine does that everytime I disocnnect/reconnect my battery, lol. I just keep the alarm remote in my arm and disarm it when it goes off....
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
