![]() Join Date: Oct 2003
![]() Well i had it running for about a week or so, but when i would get on it there was a loud noise under the valve cover(timing chain). After replacing the chain and guides and my tensioner, i havent been able to start it. I got fuel i got spark, still a no go. when i put on my chain it was all accurate with the marks on the cam gears and that lower gear. and i made sure it was at TDC. i also stabbed the CAS right, being that it was my 4th time doing it, and it worked before the chain replacement. heres the list of whats it doing.
-backfiring through the intake -oozing a thick black smoke from the fart can -backfiring a little (exhaust) -wetting the hell outta my plugs(new plugs) -turning over then itll stop then turnover again (never letting off of the key -if you hook up a timing gun it didnt flash(but it does spark,might be the gun) -if you give it some gas while trying to start it will back fire a little out the can. please help - |
