Old 03-25-2002, 09:02 AM   #1
tapand
tapand is an unknown quantity at this point
Hi,
I have a 1989 nissan 240 sx. Yesterday , all of a sudden i lost pressure in my clutch and i think its the hydraulic system whihc might be leaking.
I wanted to know if someon had the sam problem and if so what needs to be done and the cost involved.
Please advice
tapand is offline   Reply With Quote
Old 03-25-2002, 09:41 AM   #2
will
will is an unknown quantity at this point
well my 91 is at the dealership right now, my pedal pretty much rests on the floor so hopefully I'll found out by lunchtime today....
-will
Honda's are like tampons, every pussy needs one
91-S13 coupe
S13koop.net coming soon...
will is offline   Reply With Quote
Old 03-25-2002, 09:50 AM   #3
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
You're probably looking at the master/slave cylinders being replaced. It could be anywhere between 100 and 200 dollars depending upon whether it's just one or both.
For now, just keep topping off your clutch reseviour, don't let it fall below the "min" line
Learn everything you can, while you still have the chance.
transient is offline   Reply With Quote
Old 03-25-2002, 10:28 AM   #4
will
ok, dealership just called me, apparently the previous owner attempted to replace the slave cylinder, just didn't adjust it correctly and so thats all they did today, $40 fix they said, fine with me, just let me get the damn shifter into each gear without feeling like I'm gonna break it off <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'>
-will
91-S13 coupe
Old 03-25-2002, 11:07 AM   #5
yenpit
yenpit is an unknown quantity at this point
if u have no hydr pressure, then one or both of your cylinders is bad.....master cyl at firewall/pedal or slave cyl at trans. u can replace one (ie if one appears to b leaking) and hope the other holds up, but often eventually replace both <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/lookaround.gif" border="0" valign="absmiddle" alt=':look:'>
'98 240SX 5spd[br]http://www.speedwisemotorsports.com
yenpit is offline   Reply With Quote
Old 03-25-2002, 05:58 PM   #6
jmancini
jmancini is an unknown quantity at this point
I had the same problem w/my 1990, happened on a trip, about 800 miles from home! &nbsp;Needless to say, I was at the mercy of the local Nissan shop. &nbsp;You should expect to replace the master cylinder AND the slave cylinder, if you want it fixed for a while! &nbsp;I paid about $325 for new parts (both MC and slave) and labor. &nbsp;I don't think its a difficult job if you're handy and have tools...I didn't have much choice! &nbsp;Good luck...
jmancini is offline   Reply With Quote
