![]() Join Date: Jan 2003
for you track guys with subframe bushings or spacers
hey
who here has aluminum subframe bushings? im deciding whether i should just get the subframe spacers or spend the extra 50 and get the aluminum bushings. i take my car to the tracks like once a month and i was wondering if anyone has experience with both.
1990 s13 IslandMotorsports, Inc. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
i have the aluminum spacers.....been on my car for like a year or less now...they are great...
i installed them with a factory se sway bar on my base model s14....and after they went on, the rear was more stable... nothing dramatic but it was noticeable |
![]() Join Date: May 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
im getting my solid subframe bushingsin later this month.
should be fun ![]() ive had spacers they are great, worththe money doing the subframe is a bigger job. no fun w/o a lift im sure. |
#4 | |
thanks |
#5 |
got them from a friend for free
doing it at their shop i dont know if need press, mabye burn them out. my friends are showing me how, i have an extra S14 subframe putting them on got the rear 2 bushings for diff cover froM SPLParts.com i dont know who made the solid ones. |
#6 |
![]() Join Date: Dec 2002
A press is recommended, but the correct blend of psychology and extreme violence will yield similiar, if not more painful, results.
#7 | |
![]() Join Date: Sep 2003
Everything with you is free free free. Share the wealth pa'tna
Hi |
#10 |
thanks for the replies guys. so if you have the aluminum bushings, theres no need for subframe spacers right?
#12 |
![]() Join Date: Jan 2004
Trader Rating: (115)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 115 reviews
the spacers have been fine for me. I have the T3 ones and they have been a great (and cheep) addition. There a simple bolt on and it only takes hand tools and a big ass crow bar. Makes the rear end WAY more stable. I had upgraded linkage, springs and shocks and a VLSD and I actually felt the rear end twisting when I grip drove hard out of a corner. VERY WORTH the $50.
#13 |
![]() Join Date: Jun 2003
I got the 8-piece set from T3. Made a comparable difference equal to going from stock suspension to full-on Tein HEs,Tie rods, and tension rods. I also burned out the rubber bushings to get an extremely close tolerance. Next on agenda is to get the solid mount pieces.
#14 |
do the collars work better than the poly spacers? for only 20 bucks more i might go with the collars.
#15 |
poly spacers are if you don't want hardcore solid connection with the subframe. I enjoy hearing the clutch engaging and the rowing of the gears, and the sound and feeling of the car shaking from the lsd. go with the collars dont skimp out and get the poly bushings, go with 8-piece. that way you could go in steps, using initial 4 to see how it feels, then put the 4 in for very solid feeling in the subframe.
