Old 03-04-2005, 01:49 PM   #1
superman0234
superman0234 is an unknown quantity at this point
Send a message via AIM to superman0234
HELP! Car running like total crap!
Ok guys, I need some serious assistance here. I heard the timing chain rattling under my valve cover today, so I popped it off to check it out. The chain is loose so I know I need to get it replaced. The valve cover gasket was soft still, so I just reused it and reattached the valve cover. I tighten it down and start up the car and now it is running absolutely horribly! The engine is shaking like crazy at idle and im getting a puhh puhh puhh sound coming from the exhaust. Sounds like total shit when I rev it too. Please guys, I need help! This is my daily driver and I read that removing the valve cover was no big deal. Well it really fucked me over! Please respond! This is an 89 sohc btw.
superman0234 is offline   Reply With Quote
Old 03-04-2005, 02:05 PM   #2
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Check all your sensor connection (MAF, etc) and spark plug wires.
MELLO*SOS is offline   Reply With Quote
Old 03-04-2005, 02:20 PM   #3
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
removing your valve cover had nothing to do with your problem, just coincidental, unless your chain is so loose you skipped a link on your chain while playing with it...but to me it sounds like you didn't have all of your spark plug wires on the spark plugs..
g2ic02 is offline   Reply With Quote
Old 03-04-2005, 04:42 PM   #4
AZiaNDriftRaceRX
AZiaNDriftRaceRX's Avatar
AZiaNDriftRaceRX is an unknown quantity at this point
Send a message via AIM to AZiaNDriftRaceRX Send a message via MSN to AZiaNDriftRaceRX Send a message via Yahoo to AZiaNDriftRaceRX
yea...chek yur plugs...
i had a similar problem..all i had 2 do was tighten up my plugs..
AZiaNDriftRaceRX is offline   Reply With Quote
Old 03-04-2005, 07:28 PM   #5
superman0234
could a loose valve cover be the cause? 4 of my bolts are stripped, the ones on either sides. Could this be a possible cause? I'll check my wires again, but I'm pretty worried that it's more than something that simple. Any other ideas would be great.
Old 03-04-2005, 11:08 PM   #6
s13gonwild
s13gonwild is an unknown quantity at this point
no valve cover would not cause this. you left something loose/unpluged, like some people said check to see that you put all plags back in...did you unplug any injectors from the harness?
s13gonwild is offline   Reply With Quote
Old 03-05-2005, 07:49 AM   #7
superman0234
I didn't mess with anything except the valve cover which I took on and off. I'm gonna go try and tighten my plugs, but I checked the wires last night and they were all secure.
