Old 03-05-2005, 07:00 AM   #1
driftracer
driftracer is making a name for him/her selfdriftracer is making a name for him/her selfdriftracer is making a name for him/her self
Send a message via AIM to driftracer Send a message via MSN to driftracer
S14 Greddy FMIC Install
Hey guys,
I have searched through these forums for a few hours, but I am not finding the right information I need for this install.
There is a mounting bracket that goes from the top of the intercooler to right under the hood release on the frame of the car. The bolt I need to use will not fit in this bracket and I am wondering if I need to drill the hole in the bracket to make it a little bigger, or am I doing something wrong?
The only drilling that any of the threads I have found said that it was necessary for the battery tray, and that has been done. Hopefully my question is clear enough for you guys to understand and answer. Thanks
driftracer is offline   Reply With Quote
Old 03-05-2005, 07:02 AM   #2
driftracer
Oh, I forgot to mention, this is being installed on a '95 240 sx...sorry about that.
Old 03-05-2005, 10:12 AM   #3
timmybgood
timmybgood is an unknown quantity at this point
i know what you're talking about.
however the bolt does fit through the bracket. you must've taken out the wrong bolt. mine fit with no problems whatsoever. i have a greddy type-s fmic on a 95.
1995 SE
timmybgood is offline   Reply With Quote
Old 03-05-2005, 11:03 AM   #4
Doriftomodachi
Doriftomodachi is an unknown quantity at this point
I thought HKS makes the type s and greddy makes thr vspl and rspl
Doriftomodachi is offline   Reply With Quote
Old 03-05-2005, 01:59 PM   #5
Red
Red's Avatar
Red is an unknown quantity at this point
I just mounted mine right to the car.. no spacer needed...
http://www.cardomain.com/memberpage/509537
http://www.imagestation.com/album/?id=4287415487
http://www.zilvia.net/f/showthread.php?t=21036
Red is offline   Reply With Quote
Old 03-05-2005, 05:30 PM   #6
driftracer
I don't get it. I looked at Red's pictures of the intercooler installed and I am wondering how you got it to fit between those two frame pieces on the chasis that meet at the end tanks. It couldnt fit, so I used that Z looking mount braket to give the intercooler an angle and actually reach the the two wholes under the frame for the bottom of the intercooler. I am seeing pictures of people using this bracket and some not using it. I am not getting anywhere with this
Old 03-08-2005, 08:40 AM   #7
driftracer
Okay, I received an e-mail from a fellow zilvia member, and he's seeming to make the most sense so far. Basically, parts of the bumper support will have to be cut to allow this FMIC to fit. If this is so, what did you guys use to do these modifications? Look's like I'll have to make another stop at Lowe's
Old 03-08-2005, 09:03 AM   #8
MakotoS13
MakotoS13's Avatar
MakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-known
Send a message via AIM to MakotoS13
im guessin a sawzall would fix this problem.
MakotoS13 is offline   Reply With Quote
Old 03-08-2005, 01:13 PM   #9
driftracer
So there is no way around this, right...to install a S14 Greddy FMIC, I have to modify the bumper reinforcement?
Old 03-08-2005, 02:03 PM   #10
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
Yes, you always have to modify bumper supports before you put FMIC kits in your car, unless you go custom and mount it farther back. But then you have to modify your car to fit it in there. Do some research next time.
Flybert is offline   Reply With Quote
Old 03-08-2005, 03:49 PM   #11
timmybgood
take off bumper support, mount intercooler, hold bumper support up to see where it needs cut, put your sawzall to use.
i also had to cut out a small section at the front of each frame rail so it'd fit snug, those pieces were only like 1.5" square
1995 SE
