Old 03-26-2002, 08:06 PM   #1
fyreline
fyreline is an unknown quantity at this point
I have the kit for my 1990 240SX . . . the simple instuctions included seem clear enough, but I'm sure a lot of you have installed these.  Please share your tips and experience to make this even easier!
fyreline is offline   Reply With Quote
Old 03-26-2002, 09:29 PM   #2
crazyikimasho
crazyikimasho's Avatar
crazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond repute
the hardest part will be getting the cluster out, just be patient and be easy on the trim, otherwise you will break something. The best wire I found to tap into was the switch on the left that flips the lights up. There are several places to ground inside the cluster. Try not to move the needles, the speedo and tach are movable, the others are not. It is one of the more simple installs I have done, on my s13. Except for getting the cluster out of course.
***PLEASE NOTE*** I am no longer affiliated with West Covina Nissan.
crazyikimasho is offline   Reply With Quote
Old 03-26-2002, 09:47 PM   #3
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
i cant take off my damn cluster the steering colum is in the way
I am GOD!
drifterx is offline   Reply With Quote
Old 03-26-2002, 10:05 PM   #4
crazyikimasho
yeah my cluster was a pain to get off because of the steering column, you just have to work it around, turning it back and forth, it will come off trust me, just not very easily. Or you could take your steering wheel off which could be just as difficult
Old 03-27-2002, 12:10 AM   #5
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
You're supposed to unbolt the 2 bolts holding your steering assembly up.  The hardest part is unhooking the plugs for your lights/hazards/etc.  When taking the gauges off, twist as you pull....or you will ruin the guage motors.  Take note of where the gas gauge was before you take the needle off (with the ignition on).  When re installing the needles, turn the power on with the ignition, but dont start the car.  The needles are actually BELOW zero with the key off...then once you turn the ignition on (without starting the car) they jump up to zero...and its at this point you will want to put the needles back on...and the gas needle to the same spot where you took it off.  (draw a pic if it helps)
M
p.s. Change the bulbs while you have the cluster out...use the Polar G hyper blue.
400x200
mbmbmb23 is offline   Reply With Quote
Old 03-27-2002, 12:27 AM   #6
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (mbmbmb23 @ Mar. 26 2002,02:10)</td></tr><tr><td id="QUOTE">p.s. Change the bulbs while you have the cluster out...use the Polar G hyper blue.</td></tr></table><span id='postcolor'>
if he's installing indiglos it won't matter as much. &nbsp;for somewhat of a custom touch though... he can use any colored 194 bulb. &nbsp;With indiglo gauges... I think the blue might blend a bit too much with the gauge faces set on blue.... anyone with pics of that setup? &nbsp;(I'd think yellow would be nice... right now i have clear bulbs but it lights yellowish).
AceInHole is offline   Reply With Quote
Old 03-27-2002, 05:54 PM   #7
fyreline
Thanx all . . . very helpful hints.
Old 03-27-2002, 11:56 PM   #8
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
Yeah, I have the hyper blue bulbs, with indiglo faces and lazer diodes on the needles (4 blue ones). &nbsp;Its pretty sweet. &nbsp;I'll take some pics once I locate a camera to borrow. &nbsp;The reason I suggested replacing the bulbs is that is such a pain to take out the gauge cluster, you might as well replace them now before the burn out in the future. &nbsp;As far as brand and color...just experiment I guess...but do it while the gauge cluster is out (you can still plug it in and test it tho...just close the garage and turn off the light to get the full effect.....also....play with the dash dimmer to see what looks good).
M
400x200
Old 03-28-2002, 11:42 AM   #9
AJ
AJ is an unknown quantity at this point
Send a message via ICQ to AJ Send a message via AIM to AJ
laser diodes?.. whaaaat.. where'd u get them?
__________
96 s14
300zx lsd
zeal b2's
AJ is offline   Reply With Quote
Old 03-28-2002, 09:55 PM   #10
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
Yeah, lazer diodes....little rings that go under your clear plastic needles on your speedo...they light up your needles. &nbsp;Ever shine a lazer pointer on the corner of a cd jewel case??..notice how the red light lights up the plastic if it hits it right? &nbsp;Same idea.
http://www.importintelligence.com/FMPro?-....A&-Edit
The one on this site (of a 240) has a red bulb installed in the gauge cluster I believe...and has blue diodes (like I have). &nbsp;Mine arent quite as bright....but mine look sweet tho. &nbsp;
m
400x200
Old 03-28-2002, 10:29 PM   #11
AJ
where did you get yours?.... &nbsp;those r kinda expensive <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''> any custom solutions.... hehe.. let me know. .thanks.
__________
96 s14
300zx lsd
zeal b2's
Old 03-30-2002, 10:42 PM   #12
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
That is where I got them. &nbsp;They had some combo deal,....full white face gauges, 2 large needle diodes, 2 small, and 6 hyper blue bulbs...for like $100ish...plus tax. &nbsp;The diodes are hooked to a dimmer knob, that you have to wire to a 12volt source (i spliced it into the cig lighter wires) &nbsp;Yeah, its pricey...but I havent seen em cheaper. &nbsp;This mod isnt for the faint of heart...it takes patience.
m
400x200
