Old 03-19-2005, 08:41 PM   #1
180SXtc
180SXtc is an unknown quantity at this point
Send a message via AIM to 180SXtc
SR Car cutting out at boost... Jinxed myself.... Help
Ok here is the deal.. The car was running fine up until today i ran to the store real quick was running good didnt really boost it though. I made a u-turn and headed back to the house I had to speed up to traffic speed so I gave it a little gas and I could hear the turbo spool up and then it just started gagging. I had this problem before and it was the plugs but i checked them they seem to be fine looked a little lean (white). So i assumed maybe injectors but all four plugs were lean which I assumed would be the case being im up 2lbs of boost and front mounted. However I checked the injectors the gangster screwdriver way and heard them clicking so that kinda rules them out but this is all at idle/vac not under load or boost. I checked the radiator for antifreeze discoloratiion none that i could see nor any bubbles. I havent checked compression yet but the car runs fine until load or boost I can cruise down the highway at 90mph but as soon as i roll the throttle i bog out and skip. As soon as my boost gauge zero's out the problem begins. I have really no idea im stumped i know it could be the maf. or vac leak but i checked all them and boost leaks. none evident. I know it couldnt be compression cause it runs fine unless someone can tell me other wise. Any ideas guys let me know and ill check them next...
91' hatch
RedHead SR20DET
Apex-i N1 Cat Back
HKS Downpipe
Blitz LM FMIC
Sr20detperf Hot Pipe
HKS SSQ
Apex-i Intake
Rays 77w 17x8
Eibach sportline
Tokico Illumina
180SXtc is offline   Reply With Quote
