Hey! I need advise regarding my 93 240sx se, It has a new clutch( about a month) and is starting to stick to the ground...I have to basically slam it in gear just to switch gears cuz the pressure point is at the very bottom, and the free space is like 95% of the clutch pedal.... also I need to know where I can get new seatbelts( not the electric ones) for my 240!! anyone know where I can get some off the internet of a place in dallas for my 240?
Married to the Mob
Your new clutch obviously sucks. You should take it back to the place that repaired it and have them see what they did wrong.
Can't give you any advice on the seat belts. And by the way, this is more of a technical question, so please post in appropriate forums accordingly. |
I would have to say the best place to get harnesses is on ebay or through a local shop. There are diff harness avalable.
3 - 4 - 5 - 6 point harness. I have never seen a six so dont whats up with them. If your not getting a racing seat/bucket then you probably want a 3 point harness. If your getting a bucket I would go 4 point. 5 point harnesses have a strap that goes between your legs and bolts somewhere in front of your seat. I dont want anything between my legs that could hurt my cookies if I wreaked so I avoid them. usually its just part of all harness anyways that you can remove. If you get a bucket for your car make sure you get the right bracket/rail. I dont know what kind of issues it causes with getting your car inspected either... trying to figure that one out now. Hope this helped a little.....
Five degrees of separation - from you and your license 91 240sx SE |
Not really sure, but it sounds like you have air in your clutch lines. Did you check the clutch master? Make sure it isn't leaking. Have someone press the clutch pedal and go look under the hood...listen for "whooshing" noises or fluid leak.
Beware the fury of a silent man, be more cautious of his silent farts.... |
