Old 04-09-2005, 08:00 PM   #1
KevinsS13
KevinsS13 is an unknown quantity at this point
Send a message via AIM to KevinsS13
KA Injen intake problem
1993 240sx
Any of you guys experience the intake tube rubbing the heat shield material on the hood? A long time ago I bought a AEM short ram and had the same problem so I ended up going back to the stock intake tube paired up with the MAFS adapter & a cone filter. I just bought a Injen intake with the cold air extention, seemed like the mounting didnt quite match up plus its rubbing. Any ideas?
Thanks in advance,
~Kevin
KevinsS13 is offline   Reply With Quote
Old 04-09-2005, 08:05 PM   #2
KevinsS13
Just a thought on my own post, maybe if I tried using a longer piece of the silicone tubing that mates the intake tube to the throttle body I might be able to get it to lay down a little more since the longer silicone tubing will give/bend more then the short one that butts the intake tube up close to the throttle body....
Old 04-09-2005, 09:57 PM   #3
SimpleSexy180
you said it
SimpleSexy180 is offline   Reply With Quote
Old 04-10-2005, 01:44 AM   #4
AllenRPS13
AllenRPS13's Avatar
AllenRPS13 is an unknown quantity at this point
is the injen intake perfect fit on yr s13? because i know a lot of intakes just like those on ebay are missing a place to put a hose to it which coming from the bottom of the car.... i don't know what that hose for...
~小アレンのリベリオン~
いくせ, 勝負た! 轟こう, オレのKRMS13!!!
オレの得意技!蹴り進入!角度の少ないドリフト!
AllenRPS13 is offline   Reply With Quote
Old 04-20-2005, 11:54 PM   #5
KevinsS13
The Injen one has every hookup. My AEM intake I bought like 4 years ago for my S13 was the same as "the ebay" ones you mention.....without the hose hookup that goes down towards the ground. Where does it go you ask? It goes down into sort of resonator box (plastic). Have you taken out the plastic box under your drivers side front fender that your stock intake plumbs to, its just like that. IMO the Injen kinda sucks as far as fitment. I used one of the silicone tubes from my AEM (it was longer) and tried to solve my problem but still the mounting seems way off to me plus its still rubbing on hood liner. What the heck its a na KA, im not gonna get any sort of HP out of it. I should have relocated the battery, lengthened my MAFS wiring and ran my intake straight down into the passengerside fender....The cold air ext seems to make a difference when the car is cool, I think once it heats up all the cool air turns burning ass HOT since the intake pipe runs right accross/next to the radiator.
Old 04-21-2005, 12:13 AM   #6
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
Humble apologies...just a minor post to clear up some confusion about cold air intake extensions...
The cold air intake extension makes a big difference when the outside ambient air temperature around you is cool like when you drive around at night. During a warmer/hot day, (like here in SoCal), the daytime ambient air temperature is a lot warmer thus reducing some of the benefit of the cold air intake....colder air has more mass due to molecular bonding...etc..blah blah blah. The intake pipe running across/next to the radiator doesn't make a difference at all be it day or night. The ambient air passing thru the inside of the intake pipe is going thru the pipe so fast that the radiant heat coming off the radiator doesn't make a difference at all. It's the ambient air temperature, (the air we breathe & feel against our skin), that makes a difference as it rushes into the intake/combustion chamber & reacts with the fuel mixture shot in by the injectors as it's exploded by the spark from the plugs. Colder better...warmer not...
Anyhow, I'm spouting from my ass again...time to shut up...
ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
Old 04-21-2005, 12:47 AM   #7
AllenRPS13
AllenRPS13's Avatar
yes, i have taken out the resonator box, but i am using the stock intake pipe again, so do i need to reinstall the resonator box again? i just scare if there will have some dust to go into the engine if i just hook the hose down there... thanks!
~小アレンのリベリオン~
