Old 03-29-2002, 10:02 PM   #1
Drift Style S14
Drift Style S14's Avatar
Drift Style S14 is an unknown quantity at this point
Hey guys i am redoing my entire sound system i changed all the speakers and proceeded to install my new deck. the problem is that the deck won;t play send anything to the speakers because of the stock amp that comes with our 240's. how do i bypass the stock amp? could  anything else be the problem? please help!
Drift Style S14 is offline   Reply With Quote
Old 03-29-2002, 10:08 PM   #2
silviasichigo
silviasichigo's Avatar
silviasichigo is an unknown quantity at this point
Well I am not one for cutting wires so What I would do Is look under the rear deck between the speakers and unplug the amp. Then I would get the wire Splicers I can't remember the name of them but they are red and snap on the wire. Well get an extension wire you can cut into 4 Pc. and put them in the extension end of the splice and connect straight to the speaker. It Will work for now until you can get a real amp.
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'>
silviasichigo is offline   Reply With Quote
Old 03-30-2002, 02:13 PM   #3
rampid360
rampid360 is an unknown quantity at this point
Send a message via ICQ to rampid360
There really should be no reason to blame the amp for no sound...You should double check your wiring to the head unit. &nbsp;If you are 100% sure your wiring is correct then bypass the amps...I've posted this a million times but here is a guide to help in the bypass. &nbsp;(my stock amps were cutting in and out and acting funny...so i bypassed and it works great now)
1 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;Blue &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;left front speaker neg. input
2 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;Black &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;right front speaker pos. input
3 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;Blue/yellow &nbsp; &nbsp; left front speaker neg. output
4 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;Brown/white &nbsp; right front speaker neg. output
5 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;Brown &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; right front speaker pos. output
6 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;Pink &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;left front speaker pos. input
7 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;White &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;right front speaker neg. input
8 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;Blue/white &nbsp; &nbsp; &nbsp;left front speaker pos. output
9 &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;Blue &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;acc.
10 &nbsp; &nbsp; &nbsp; &nbsp;Green/red &nbsp; &nbsp; &nbsp; on/off
11 &nbsp; &nbsp; &nbsp; &nbsp;Purple &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; left rear speaker neg. input
12 &nbsp; &nbsp; &nbsp; &nbsp;Pink &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;right rear speaker neg. input
13 &nbsp; &nbsp; &nbsp; &nbsp;Green &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; left rear speaker neg. output
14 &nbsp; &nbsp; &nbsp; &nbsp;Pink &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;right rear speaker neg. output
15 &nbsp; &nbsp; &nbsp; &nbsp;Blue &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;right rear speaker pos. output
16 &nbsp; &nbsp; &nbsp; &nbsp;Green &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; left rear speaker pos. input
17 &nbsp; &nbsp; &nbsp; &nbsp;Blue &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;right rear speaker pos. input
18 &nbsp; &nbsp; &nbsp; &nbsp;Red &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; left rear speaker pos. output
19 &nbsp; &nbsp; &nbsp; &nbsp;Blue &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;acc
20 &nbsp; &nbsp; &nbsp; &nbsp;Green/red &nbsp; &nbsp; &nbsp; on/off
Splices:
1 to 3
2 to 5
4 to 7
6 to 8
11 to 13
12 to 14
15 to 17
16 to 18
For every winner there are dozens of losers. &nbsp;Odds are you're one of them.
rampid360 is offline   Reply With Quote
Old 03-31-2002, 11:08 PM   #4
AJ
AJ is an unknown quantity at this point
Send a message via ICQ to AJ Send a message via AIM to AJ
well,, u do need to blame the amps if your deck is ampin the signal as well... a signal amped twice = naasty... (i think anyway.... it sure didn't work on my car till i redid ALL my wiring and got a real amp)
__________
96 s14
300zx lsd
zeal b2's
AJ is offline   Reply With Quote
Old 04-01-2002, 12:17 AM   #5
misnomer
misnomer's Avatar
misnomer has a little shameless behavior in the past
Send a message via AIM to misnomer
An aftermarket deck played through my factory amps to aftermarket speakers. It sounded like ass on a warm summer day, but it played nonetheless.
Rowsdower saves us and saves all the world!
misnomer is offline   Reply With Quote
