Old 04-18-2005, 08:12 PM   #1
crazy9ceguy
crazy9ceguy is on a distinguished road
Send a message via AIM to crazy9ceguy
Infamous 2500 rev limiter problem on s13 redtop
yep my car was running fine until today when i was driving home from school, went over some little bumpy road as usual then i noticed my car stalled. So i start her up again and drove it, but, the car wouldnt go pass 1500 rpms without shaking the whole car and running rich. in neutral the car wouldnt rev past 2500 rpms, its not the afm, I changed it with a friend and its the same thing, so which parts can be fucked up? this is a redtop in a s14 zenki. the car was runing for a year without problems.
crazy9ceguy is offline   Reply With Quote
Old 04-18-2005, 08:41 PM   #2
daredevildoug
daredevildoug's Avatar
daredevildoug is making his/her stupidity well-knowndaredevildoug is making his/her stupidity well-knowndaredevildoug is making his/her stupidity well-knowndaredevildoug is making his/her stupidity well-known
make sure your o2 is properly pluged in.. check all of that plugs to make sure
-de
daredevildoug is offline   Reply With Quote
Old 04-18-2005, 08:55 PM   #3
crazy9ceguy
o2 sensor is plugged n right, ill check the plugs tomorrow, how do i know if they are not useable anymore? the car starts up fine and normal, just the revving part.
Old 04-18-2005, 11:50 PM   #4
90rps13
90rps13 is on a distinguished road
Send a message via AIM to 90rps13 Send a message via MSN to 90rps13 Send a message via Yahoo to 90rps13
Sounds like your MAF is going bad...
90rps13 is offline   Reply With Quote
Old 04-19-2005, 01:43 AM   #5
TheTicTac
TheTicTac's Avatar
TheTicTac is a well-known jackass
Or you have a vac leak somewhere
*GorgeousGarage* L.oose S.ocks D.aisuke !
TheTicTac is offline   Reply With Quote
Old 04-19-2005, 02:09 AM   #6
Blues13
Blues13 is an unknown quantity at this point
Yea, sounds like a coupler came loose or something. Check all your piping to see if you have leaks. By now, your plugs are probably getting pretty fouled too.. so you might as well check/change that. If your plugs are all black, then they need to be cleaned, or better yet, replaced as they're cheap.
Blues13 is offline   Reply With Quote
Old 04-19-2005, 02:54 PM   #7
ultraDorksGarage
ultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura about
bad temp sensor(not resistor) will dump fuel too.
ultraDorksGarage is offline   Reply With Quote
Old 04-19-2005, 03:37 PM   #8
s14turbosilvia
s14turbosilvia has a little shameless behavior in the past
Send a message via AIM to s14turbosilvia
It's your maf, check all wires and connections to the MAF.
92 coupe, teh sex.
s14turbosilvia is offline   Reply With Quote
Old 04-19-2005, 04:13 PM   #9
crazy9ceguy
well i checked the maf, the harness, and hoses, all worked, maybe its the ECU.
Old 04-19-2005, 04:45 PM   #10
Pepperoni
Pepperoni's Avatar
Pepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nice
Send a message via AIM to Pepperoni
did u clean the MAF? not just check if it was plugged in
Pepperoni is offline   Reply With Quote
Old 04-19-2005, 07:05 PM   #11
katbak
katbak is an unknown quantity at this point
I had a similar problem
Same thing, stalled - wouldn't rev past 2500
But when i put it into gear it also stalled
It's at the shop now and they ran the MAF through a computer and it went bad, so I'm getting a z32 maf put in, hopefully i'll be good, if you're still wondering I'll keep you posted.
(Should be back tomorrow -- or i'll flip)
katbak is offline   Reply With Quote
Old 04-20-2005, 01:20 PM   #12
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
Did you try pulling codes first?
It's not letting you rev over 2500rpm for a reason, not 'cause it's mad at you 'cause you didnt buy it synthetic oil for its last oil change...
Pull codes first before you start futzing around with other stuff.
Did you also consider that the wiring TO the MAF might be bad, not actually the sensor?
Good luck
kazuo is offline   Reply With Quote
Old 04-20-2005, 03:44 PM   #13
NemeGuero
No more nissan.
NemeGuero's Avatar
Art's all about the codes!! =)
Old 04-20-2005, 07:21 PM   #14
crazy9ceguy
well i was driving it to the shop today and when i got there everything is fine again, and yes i use synthetic oil, motul racing oil to be exact.
Old 04-20-2005, 11:25 PM   #15
kazuo
You missed my attempt at a joke. :/ Oil has nothing to do with it, I was attempting to equate the car throwing a hissyfit 'cause you didnt use synthetic to being similar to a woman throwing a hissyfit 'cause you took her to McDonalds instead of that expensive Italian place.
Which cars don't do, 'cause they're cars.
Whatever
Check codes, then go from there.
