Old 05-17-2005, 04:30 PM   #1
silviadriftr
silviadriftr's Avatar
silviadriftr is a well-known jackass
Send a message via AIM to silviadriftr
Question about lash killer kit?????????
I am running Hks 272 step 2 cams and have been told differnet things. I am wondering if anyone here is running 272 step 2's with the Solid mount lash killer kit?
UNLIMITED PERFORMANCE
WWW.TURBODAVE.COM
http://www.mountainboost.com/415/silvia.wmv
Record holding-473whp-sr20det
stock cams and bottom end
silviadriftr is offline   Reply With Quote
Old 05-17-2005, 05:34 PM   #2
ultraDorksGarage
ultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura about
i was told by some other peeps here that the solid pivots needed specialized cams to go with it. but other friends said it doesnt matter, its just with the solid set, u can max out cam profile(kinda like a roller cam for pushrod motors).
remember when doing change, u will have to reshim your valvetrain. o the joy of a shim and a bucket valvetrain....
ultraDorksGarage is offline   Reply With Quote
Old 05-17-2005, 05:44 PM   #3
silviadriftr
I have the ferrea valves, dual springs, retainers, lockers, and locators already. The problem I am having is the rocker arms staying in place at launch off the 2 step. I run the AEM EMS and with launching off the 2 step at between 6900-7200 rpm and only holding the 2 step in for 3-5 sec I have had 1 lash cap come out and 3 split rocker arms. I have been told that the solid lifters are supposed to help this problem and also valve float but I am not running the step 3's yet. I just want to make sure that you can run the solids with the HKS 272 step 2's. Or if anyone has run into this problem and how I can fix it before I kill the motor.
WWW.TURBODAVE.COM
Old 05-17-2005, 06:20 PM   #4
AenjukuCar
AenjukuCar's Avatar
AenjukuCar is an unknown quantity at this point
Send a message via AIM to AenjukuCar
Look at it this way, stock SR20DET lifters 560 bucks from enjuku brand new, or tomei solid pivot lifters for 278ish with test shims and shims from raretrick. But also with going with the solid pivot lifters, you will need to go with the pro-cams from tomei, which you will also probably need then new vavle springs and retainers to go with it.
AenjukuCar is offline   Reply With Quote
Old 05-18-2005, 04:17 PM   #5
silviadriftr
Well, I got off the phone a little while ago with HKS and the word on the lash killer kit is that you can run the kit with any of the different step cams they offer. The only one they require use for it with is the step 3, but it will work. So i guess I will try that and bronze valve guides and see how it goes. If anyone else has any input please let me know. Thanks
WWW.TURBODAVE.COM
Old 05-18-2005, 07:02 PM   #6
ultraDorksGarage
oh shizz, i forgot, i have the tomeis, and u have to alter the valve cover.
secondly, u did reshim the bucket-shim setup after the valve work right?
Old 05-19-2005, 04:26 PM   #7
silviadriftr
I didn't have any problems with clearance on the cams with the valve cover. And they don't say anything about having to do so. What part of the valve cover did you have to modify?
Well, I am only running the stage 2 272's from hks which they don't call for the shim kit or upgraded lifters. And ferrea did not say anyhting as well. Do you have to shim the factory lifters? I didn't know you could do that with the factory ones.
WWW.TURBODAVE.COM
Old 05-20-2005, 07:06 PM   #8
ultraDorksGarage
anytime u replace valves, lifter/solid pivot, valve seats, locks, or buckets/shims, u have to reshim the valvetrain on an SR.
u can take a chance and not but its what u are supposed to do. SR motors are whats called a shim and a bucket. per cylinder 1 cam lobe, 1 rocker activates 2 valves. one valve has a bucket(slotted shim/wear bushing) other valve has a shim sitting on top of retainer. if u dont spec the shims out when changing any of the above components, that rocker will be uneven ( 1 valve will be higher than the other, leaving rocker tilting to one valve). high rpm will have rocker possibly shoot out.
most shops when setting up shim and a bucket heads, grind the tip of the valve to the extended height of the old valve. that way you put valvetrain back to its original place and u have valvetrain close to original specs. this is not the proper way but will do for most people. proper way is reshiming the other valve(opposite of the bucket).
btw, SR valves are sodium filled on the exhaust side, out of curiosity, are u trying for an ultra light weight high rpm motor?
