Old 04-05-2002, 01:42 AM   #1
wav399
wav399 is an unknown quantity at this point
Will 245/40/17 's Kumho Ecsta's fit on a 17x7 wheel?
wav399 is offline   Reply With Quote
Old 04-05-2002, 02:09 AM   #2
BryanH
BryanH is an unknown quantity at this point
Yeah, but those tires might be a bit fat on the wheel.  I'm running 205/55/14 on some 14x5.5" wheels... talk about sucked-in sidewalls!  There comes a point where a tire too wide for a rim will give worse performance than a narrower tire that is more stable on the rim.  Might want to look into 225s?
Only reason I run 205s on my skinny-arse wheels is because I don't have the money for wide wheels. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''> &nbsp;The 14x5.5s are the factory wheels which now run race rubber.
&lt;i&gt;&lt;a href=&quot;http://community.webshots.com/user/bryan_h&quot;&gt;Straightaways are for fast cars. Corners are for fast drivers&lt;/a&gt;.
&lt;br&gt;[ &lt;a href=&quot;http://move.to/theMR2&quot;&gt;1987 Super Red MR2&lt;/a&gt; | &lt;a href=&quot;http://home.earthlink.net/~bryan64/pics/newtoy/latenightrollabig.jpg&quot;&gt;1985 Corolla GT-S hatch&lt;/a&gt; ]&lt;/i&gt;
BryanH is offline   Reply With Quote
Old 04-05-2002, 03:22 AM   #3
DuffMan
DuffMan's Avatar
DuffMan is an unknown quantity at this point
Send a message via Yahoo to DuffMan
Acording to the Tire Rack those tires need a 7.5 inch to 9 inch wheel with 8 inch being recommended. No it would not fit, and wouldn't be safe, and would have poor traction due to bowing in the side walls.
Actually, the sidewall height has a lot to do with how wide a tire you can run. Bigger sidewalls will allow a wider tire to be used with a given rim. So 245 tires might fit on some 7 inch wheels, but not a 40 series. You should probably look at running a 225/45.
DuffMan is offline   Reply With Quote
Old 04-05-2002, 11:06 AM   #4
geeaj
geeaj is an unknown quantity at this point
Interesting. I have a similiar issue since I have &nbsp;set of 17x7 koenig villians that I want to run. The offset is 40mm so I know I will have to go with some spacers if I want a flush fit.
So your saying 225/45/17 is okay on this size rim? I called tire rack and they recommend 215/45/17 but I want a bit more "tire" so I can fill the fender well. I run kyb agx+prokit.
Beware the fury of a silent man, be more cautious of his silent farts....
geeaj is offline   Reply With Quote
Old 04-05-2002, 12:12 PM   #5
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
Tire rack is right - a 215 is the perfect size for a 7" wheel. &nbsp;225 for 7.5" (although you can get it on a 7")
A 245 just ain't gonna work! &nbsp;The bead would be weak and the sidewalls would look horrible. &nbsp;Not good for performance or safety. &nbsp;Besides, with a 40 series tire, just try to find a shop that will mount something that wide on that rim! &nbsp;It may actually be impossible.
HippoSleek is offline   Reply With Quote
Old 04-05-2002, 03:13 PM   #6
wav399
People say that the Kumho's are actually more skinny than regular tires and that wider tires (than normal) might fit. &nbsp;I have 215/40/17 on 17X7 wheels right now and it looks like a wider tire could go on but I'm not sure about 235 or 245?
Old 04-08-2002, 01:09 AM   #7
wav399
for some freak incident of nature I have 225/60/15's on the stock 15X6 rims and these seem to be fine so what about 245 skinny Kumho's on a 17X7?
Old 04-08-2002, 11:27 AM   #8
DuffMan
DuffMan's Avatar
What part of "no" is so confusing?
These are Kumho's guidelines specific for that exact model and size of tire and they say it wont fit. 225/45 will give you the most traction possible with that wheel.
Old 04-09-2002, 01:27 AM   #9
wav399
I think it's the "no" part. &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>
&nbsp;I guess I just wanted somebody to say yeah you can do it but you're right probably with the 225's.
Old 04-10-2002, 07:47 AM   #10
JoseS13
JoseS13 is an unknown quantity at this point
Send a message via AIM to JoseS13
245 40s will fit on a 17x7 rim i have them on my car. I don't have any problems with them as far as handling they handle a lot better than stock rims and tires. Bulging out of the rim is not a problem, they stick out a little but nothing major. One of my friends also has a 240sx with 255 45s on 17x7 rims and he doesn't have problems either. I've had those tire on my car for about 8 months and never had a problem. There a bit worn out now and guess what, I'm putting 255s on. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
89 s13 SR[br][email protected][br]12 psi,93 oct,t25
JoseS13 is offline   Reply With Quote
Old 04-10-2002, 08:37 AM   #11
MDSrRider
MDSrRider is an unknown quantity at this point
235's work great on a 17x7 wheel thats what ive been running for 2 years
I LLLOOOOOVE THE COCK!!!!!!!!!!!
MDSrRider is offline   Reply With Quote
Old 04-11-2002, 12:53 AM   #12
wav399
Now that makes me <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''> ! &nbsp;Okay so what do you both have S13, S14's? &nbsp;And what type of tires do you guys use? &nbsp;Also, what's the front and Back set up?
Old 04-11-2002, 09:28 AM   #13
prInce
prInce is an unknown quantity at this point
Send a message via ICQ to prInce
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (wav399 @ April 08 2002,03:09)</td></tr><tr><td id="QUOTE">for some freak incident of nature I have 225/60/15's on the stock 15X6 rims and these seem to be fine...</td></tr></table><span id='postcolor'>
225/60R15 front and rear both? &nbsp;on an S13/S14?
i got 205/60R15 all-seasons.. i DEFINITELY need at least 16 racing wheels with Z-rated tires <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/satisfied.gif" border="0" valign="absmiddle" alt=':satisfied:'>
'95 240sx LE KA24DE
D2 Coilovers - 7/5 Spring Rate
2.5" pipe w/ractive muffler & magnaglow hi-flow cat
Injen Intake
Juran Front Upper Strut Bar
prInce is offline   Reply With Quote
Old 04-11-2002, 11:04 AM   #14
HippoSleek
HippoSleek's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (prInce @ April 11 2002,10:28)</td></tr><tr><td id="QUOTE"><!--QuoteBegin--wav399+April 08 2002,03<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (wav399 @ April 08 2002,03<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>9)</td></tr><tr><td id="QUOTE">for some freak incident of nature I have 225/60/15's on the stock 15X6 rims and these seem to be fine...</td></tr></table><span id='postcolor'>
225/60R15 front and rear both? on an S13/S14?
i got 205/60R15 all-seasons.. i DEFINITELY need at least 16 racing wheels with Z-rated tires <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/satisfied.gif" border="0" valign="absmiddle" alt=':satisfied:'></td></tr></table><span id='postcolor'>
225/60 series tires have HUGE sidewalls. &nbsp;You have a lot more to play with in that case (and a lot more instability for performance). &nbsp;If you +2 the rims, you are going to be cutting down that height which reduces your margin of error and increases the rigidity of the sidewall...
but whatever, it is clear that the widest tire is best... regardless of how well it is capable of performing &nbsp; <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sigh.gif" border="0" valign="absmiddle" alt=''> &nbsp; I give up!
Old 04-11-2002, 07:36 PM   #15
JoseS13
We both have S13s, I have falken tires 225 45's in the front and 245 45's in the rear 17x7. My friends S13 has 225 in the front and 255's in the rear.
Jose
89 S13 SR
[email protected]
12psi 93oct 2.3-60'
Old 04-12-2002, 02:30 AM   #16
wav399
I have 225/60/15's on the rear only. &nbsp;However, this is a temporary thing. &nbsp;I'm waiting on my summer rims to be fixed. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/cool.gif" border="0" valign="absmiddle" alt=''>
Old 04-12-2002, 07:17 PM   #17
smooth240
smooth240 is an unknown quantity at this point
Send a message via MSN to smooth240
I have seen it done on a 7" rim. It didn't look quite right. The side wall looked as distored (buldged out something fierce).
He said it performed well though with no roll.
smooth240 is offline   Reply With Quote
Old 04-12-2002, 07:38 PM   #18
tnord
tnord's Avatar
tnord is an unknown quantity at this point
some people never learn hippo, or they learn the hard way
tnord is offline   Reply With Quote
Old 04-12-2002, 08:18 PM   #19
Red
Red's Avatar
Red is an unknown quantity at this point
Why push it guys, Just spent the $$$ and run the right stuff
Do 245/40/17 on some nice 17/8 race wheels
Or Even 255/40or35/17 on some nice 17/8.5 to 9 race wheels
I know people dont have $$$ to blow on everything, But dont skimp on the important stuff like Wheels.... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/nervous.gif" border="0" valign="absmiddle" alt=':nervous:'>
http://www.cardomain.com/memberpage/509537
http://www.imagestation.com/album/?id=4287415487
http://www.zilvia.net/f/showthread.php?t=21036
Red is offline   Reply With Quote
Old 04-13-2002, 12:35 AM   #20
wav399
In my case it's not the $, its that I love my wheels so much I do not want any other style and they are only made in 17X7 and 18X7. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/inlove.gif" border="0" valign="absmiddle" alt=''>
