Old 05-20-2005, 08:37 PM   #1
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Altima fans help =(
I just received my Altima fans to match my Koyo and Dakota fan controller...But how the f am I suppose to wire these things up? I understand the fan controller part but how should I do the power for the fans?
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 05-20-2005, 08:55 PM   #2
S14DB
AFC #1
S14DB's Avatar
There is this thing in your engine bay called a battery...
Old 05-20-2005, 09:13 PM   #3
wootwoot
whats that look like? I have some aaa's in the dash for my flashlight, do you mean those??
But should I wire them with relays or whats the deal? I read some other thread in which they said 2 were ground and 2 were power; You have to run power through both of the +'s to get the fans on high speed. I'm looking to confirm that and just a wiring diagram would be a nice thing to have right about now. I have the wiring diagram for the fan controller which made that easy
Old 05-20-2005, 09:18 PM   #4
S14DB
AFC #1
S14DB's Avatar
I would wire one to the AC fan leads and one to the controller. Unless the controller has a AC input.
Old 05-20-2005, 09:20 PM   #5
wootwoot
It does =)
Old 05-20-2005, 09:54 PM   #6
MakotoS13
MakotoS13's Avatar
MakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-known
Send a message via AIM to MakotoS13
woot, get a painless wiring fan relay kit for like 25 bucks. its worth it and has instructions.
MakotoS13 is offline   Reply With Quote
Old 05-20-2005, 10:09 PM   #7
wootwoot
Care to point me in a direction where I could pick one up? Just Autozone or anything like that?
Old 05-21-2005, 01:34 AM   #8
TheSnail
TheSnail's Avatar
TheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to all
stick the Power wire to the fuel pump fuse. Replace the fuse with a 15 amp, instead of 10. Takes 28 seconds, simple.
TheSnail is offline   Reply With Quote
Old 05-21-2005, 07:20 AM   #9
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
1) Yes, you need relays...4 of 'em.
2) Like OEM S14 fans, each of those has 2 speeds...hence the 4 wires. So if you want to get the most out of 'em, you need a (switched power/ground using the relay) X 2 for each side.
If you use a standard Bosch relay, then wire it like so:
30 - + from battery
87 - + wire going to the fan
86 - ground (use this for a on/off switch)
85 - switch wire that's + when the ignition is turned on.
So when you flip your switch, it will ground the relays...they turn on, power to the fan. I'd run 2 switches, one for each fan (so each switch grounds 2 relays).
- Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
