Old 06-02-2005, 10:59 PM   #1
Sil-EightyNY
Sil-EightyNY is an unknown quantity at this point
Send a message via AIM to Sil-EightyNY
SR Boost bouncing back
I have the stock turbo and a greddy profec B II and i drive on 7.5 psi everyday but do like to up it to 13 one in a blue moon. The only problem with upping the boost is that it does reach that point and bounces right back to 7.5???? Where is the problem? I want to up the boost at the track and keep it at 13 throughout the whole gear. And also is 8k degrees normal for cruising on the highway or is it too hot? Also, why is the oil pressure really high lige 6 at idle when the car is cold and when it warms up, the oil pressure is at .5 and that scares me. (not like on a honda). Is it my pump or is that normal??? Thanx
Tom
PS Its and SR20 black top S13
Sil-EightyNY is offline   Reply With Quote
Old 06-03-2005, 01:47 AM   #2
Rezlo
Rezlo is an unknown quantity at this point
Send a message via AIM to Rezlo
All cars oil pressure will drop once its warmed up because the oil becomes thinner with heat, .5 is a tiny bit low but normal never the less if the oil is at full temprature at idle.
Your dropping boost could be a variety of things, IE: restrictive exhaust, restrictive intake, incorect timing ectr, search for it many posts about it.
Rezlo is offline   Reply With Quote
Old 06-03-2005, 02:10 AM   #3
kandyflip445
kandyflip445's Avatar
You would be dead if your car was running at 8000 degrees....
My 240 vBgarage
Old 06-04-2005, 05:44 PM   #4
240SxTYLE
240SxTYLE's Avatar
240SxTYLE is an unknown quantity at this point
Send a message via AIM to 240SxTYLE
your boost is falling off cause incorrect tunning on your profec-b. I had the same problem, but after a little tinkering i got it right.... first thing to do is throw the greddy instructions away. there is a good site somewhere with a write up for 10lbs. and a 1-bar setting. I havent tried to up my boost or mess with it so i really cant tell you how to do it.. sorry
Second love
First Love (my girl, not the honda)
240SxTYLE is offline   Reply With Quote
