Old 06-03-2005, 06:21 PM   #1
aznpoopy
aznpoopy's Avatar
1995 ka24de *pinging noise*
1995 OBDI ka24de
120k on the clock
both timing chain guides removed
got a very quiet pinging noise... like metal tapping on metal coming from somewhere in the engine. trouble is over the stupid fan and the exhaust i can't pin point it. it gets more noticeable if there's more load at idle (like turning on the highbeams).
my friends all think i'm crazy because they can't hear shit. but i know my car.
thought it might be the chain tensioners are a little stuck from age, making the chain a little slack causing it to tap against something. anyone know what that sounds like?
any ideas?
aznpoopy is offline   Reply With Quote
Old 06-03-2005, 10:27 PM   #2
Dorifto89
Dorifto89's Avatar
Dorifto89 will become famous soon enoughDorifto89 will become famous soon enoughDorifto89 will become famous soon enoughDorifto89 will become famous soon enoughDorifto89 will become famous soon enough
Detonation maybe?
Dorifto89 is offline   Reply With Quote
Old 06-03-2005, 10:57 PM   #3
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Im thinkin maybe your lifters? Try pouring oil directly on them. Drive around for a day or so, see if its still tapping.
SochBAT is offline   Reply With Quote
Old 06-04-2005, 12:02 AM   #4
aznpoopy
aznpoopy's Avatar
ill give that a shot this weekend.
don't think its detonation... timing is a-ok and it's pretty much a stock ka24. i use high octane gas too.
Old 06-04-2005, 09:55 AM   #5
Dream240
Dream240's Avatar
Dream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond repute
Does the pinging get faster when you rev up the engine? Or is it a constact sound from idle to 2000rpms? Also does it ever completely go away?
My guess is you have either a floating valve (bad valve spring), loose timing chain, or worn valve guides (causing the valve stem to rattle at low rpms, too much clearance in there).
Does your car blow blue smoke? A sure fire way to eliminate bad valve guides is to take your car out to a hill, punch the gas to about redline then back off, do this 3 times. Then stop and check to see if you have a trail of blue smoke behind you....if so it's worn guides.
Good luck.
Don't mess with my monkey...he's loaded.
Dream240 is offline   Reply With Quote
Old 06-04-2005, 11:15 AM   #6
Redsunz916
Redsunz916's Avatar
Redsunz916 is an unknown quantity at this point
how bout the timing chain guide, it is a COMMEN PROBLEM with ka24de. when i rebuilt mine i only put the main one. theres usually 3 but u only need one cuz the other 2 break and nissan removes them as a factory defect.
Redsunz916 is offline   Reply With Quote
Old 06-04-2005, 10:43 PM   #7
aznpoopy
aznpoopy's Avatar
thanks for the suggestion red, i took out the two upper timing chain guides a long time ago.
thanks for the info dream. i have a feeling that may be my issue. i checked out the procedure in the FSM. seems like i might as well do a full timing chain job, change the head gasket, and replace all the valve crap in the head. i don't know if that's feasible as a weekend project.
i wonder if i should just find myself a low mileage ka24de and drop it in instead. what a headache...
Old 06-05-2005, 07:41 AM   #8
Dream240
Dream240's Avatar
Well, if you want to learn how the KA is put together, get another block and swap it in. then you can tear down your old one to your hearts content!!
First things first though.....do a timing chain replace first. Hell of a lot cheaper and easier than doing a swap. Might fix it. If not then you know what you have to do.
Old 06-05-2005, 08:52 AM   #9
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
Actually 1995 are OBD2 with a compression of 9.6:1 ment for 91 octane at 20BTDC. If your using 91 at 20btdc that isn't your problem, unless your plugs and wires exceed over 30,000. "Typical situation"
If you have what is more of a pinging and rattling that sounds as if it comes from the front of the head that would be the 2 top timing chain guide tensioners. Nissan actually has mandated/recalled that the 2 top tensioners are faulty and can break. This will also mean the addition of a new timing chain, do to the fact nthat the chain can stretch sooner than later from glidding along the cam sprocket teeth. This problem usuall starts to occur in the KA24de at about 60,000 to 100,000 depending on how much high rev abuse the KADE has been through.
There is another condition that if it comes from anywhere else in the head you may have what are called floating valves but that sound you usually can't hear until about 3000RPM......
BigVinnie is offline   Reply With Quote
Old 06-05-2005, 02:09 PM   #10
aznpoopy
aznpoopy's Avatar
yeah dream, i'm looking to pick up a low mileage ka24 and drop it in. everyone tells me its a helluva lot easier then trying to rebuild the head in 2 days. timing chain job isn't a bad idea either, but i think i'm just going to do a swap. i'll do the timing chain job on the 'new' motor instead. sourcing one out should be pretty quick. i have to do a clutch job anyway, so the timing is actually pretty good. in the meantime, i'm just going to pop off the front cover and see if it's the upper and lower tensioners. i'm thinking they might be partially frozen with gunk.
thanks for the suggestions bigvinnie. actually 1995 240sx's are split between OBDI and OBDII, depending on the date of manufacture. i already removed the timing chain guides a long time ago. i set my timing myself as well. timing chain tensioners? i think you mean timing chain guides. the timing chain tensioners don't really break oh a dohc motor. they just get clogged up with gunk and stop fucntioning, resulting in a slack chain.
Old 06-05-2005, 07:39 PM   #11
supracrazy
supracrazy has made poor choicessupracrazy has made poor choicessupracrazy has made poor choicessupracrazy has made poor choicessupracrazy has made poor choicessupracrazy has made poor choices
I have that same problem but it dosn't happen until the car is under loadand at high rpms. When i just rev it nothing happends It jsut revs how it should, but as soon as I put it in gear it stutters at around 2krpm 3krpm 3.5krpm and when i get to about 5500rpm the engine seems to loose all power and slowly go to 6k then the engine wont rev any higherwhile in that gear. Also it doesnt ideal properly it keeps goin from about 700rpm to 1200rpm over and over. and ocasionally goes lower and then stalls. I changed all my plugs and im not sure it if is a ingition problem ot valve timing problem The car is a Stock 95 with 131 thousand miles. also do yuo think it has somthing to do with the pressuer plate?
I got the car when it had 128 thousand and the only probleme then was the ideal but now it is just plain screwed up.
Thanks,
J.Brown
please help me
also I dont wanna invest that much in the motor because I will be doing a swap soon, but it is just unbearable to deal with it staling at lights and accelerating all fucked up. Literally the car like jumps forward and backwards when it stutters during the rpms above.
and I only use 93 octane
supracrazy is offline   Reply With Quote
Old 06-05-2005, 11:37 PM   #12
nistech
nistech will become famous soon enoughnistech will become famous soon enoughnistech will become famous soon enoughnistech will become famous soon enough
Send a message via AIM to nistech
try using 87 see what happens it is most likely detonation cuz u use high octane gas
nistech is offline   Reply With Quote
Old 06-05-2005, 11:38 PM   #13
nistech
why would u use 93 if the car is stock...
Old 06-06-2005, 06:08 AM   #14
Dream240
Dream240's Avatar
Uh...93 octane gas won't cause detonation unless you have a deisel. Detonation occurs when you have too low an octane. Nissan recommends 91 octane in all 240s so 93 octane isn't going to hurt it or really help it all that much either. Maybe a little more power but not noticable in the cockpit. 87 octane will likely make the problem worse.
You have a vacuum leak for starters. That's why you have an erratic idle. Also your acceleration problem sounds like a slipping clutch. Let me guess....have you been dropping the car into gear at about 3-5 rpms??? Even for just one night? Cmon be honest....it's too tempting not to right? I'm sure that's your problem, bad clutch will slip the heavier the load gets. More rpms = heavier load = more slippage. Time for a new clutch kit.
Old 06-06-2005, 06:51 AM   #15
supracrazy
Hmm I never thought it might be a vacuum leak but. I dont think it is a cltuch probleme because I always thought that the clutch slips only unter heavy load. but when i even accelorate slow. it jupms and when accelorating fast it doent jump as bad.
but I will tri and fint the leak. somehow
Old 06-06-2005, 11:15 AM   #16
Dream240
Dream240's Avatar
Okay to find the vacuum leak, get a can of throttle body intake cleaner. Start the car and spray the can into areas like around the intake manifold gaskets, the throttle body gasket, the various vacuum hoses around the manifold. As you spray pay attention to the idle of the car. If it gets worse as you spray the can in a particular area then you've got a leak around there. Also you will notice the fluid being sucked in and not just running off.
Here's some other check points:
Is your car stock? Do you have an aftermarket intake? If so make sure all your hoses are connected properly. Check your MAF. Clean the sensor with some rubbing alcohol and a Q-tip.
Check your air filter for dirt build up. A badly clogged air filter can cause some problems. Maybe you go a dirt clod or rock stuck in there....trust me it can happen.
Are your spark plugs & wires new? Check to make sure your spark plugs are installed correctly (tightened properly) and that your wires are hooked up properly, ie. make sure Cyl. 1 wire is connected to port 1 on the dist cap etc.
I had an erratic idle when I first got my 96' and it turned out to be the upper intake manifold gaskets. Dealer replaced them and no more problems. If that's where your having a problem good luck those things are a PITA to change out in your garage.
Good luck.
Old 06-06-2005, 01:30 PM   #17
BigVinnie
BigVinnie's Avatar
[QUOTE=aznpoopy]
timing chain tensioners? i think you mean timing chain guides. QUOTE]
Yeah your right sometimes I get into typing before I am thinking the 2 top guides have a recall.
Old 06-06-2005, 03:56 PM   #18
Dream240
Dream240's Avatar
So does that mean that Nissan will actually go in and pull those guides out for free? Or maybe do a full timing chain job? Anyone know?
Old 06-06-2005, 09:22 PM   #19
evanl85
evanl85's Avatar
evanl85 is an unknown quantity at this point
I believe it is a TSB, not a recall, so no they will not do anything at all for free.
evanl85 is offline   Reply With Quote
Old 06-07-2005, 06:11 AM   #20
Dream240
Dream240's Avatar
...damn it...
