Old 06-13-2005, 01:38 PM   #1
Listen2BobM4rley
Listen2BobM4rley is an unknown quantity at this point
s13 PROBLEM- Please help.
Ok this might make me sound like an idiot, but this is a real problem. So I was having problems with my thermostat, like it would overheat a little. So yeah I got a new gasket, and tested the thermostat, its fine. The last person had used gasket maker, that goo stuff, but ok. So I fixed it and put in the new thermostat gasket, and it was fixed. The original problem was it was leaking, and that is why it was going all crazy, cuz loss of pressure and yeah. The day after I look under the car to check for leaks, and its leaking again. I put more water, and now it doesn't leak as long as I don't drive the car. When it gets hot it leaks from the thermostat. I have only put water in there, no coolant cuz thats a waste right now. So what do u think I should do? I fixed it and it is still leaking. I don't understand how water gets through, how does it leak out where a gasket it?
Listen2BobM4rley is offline   Reply With Quote
Old 06-14-2005, 02:27 AM   #2
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
its called the system is unable to pressurize so you overheat faster. its called heat expansion as well, sure it makes a good seal at cold temps, once the motor heats up, everything expands, including unseen leaks. just go buy a freaking gasket and some waterpump gasket maker and coat the bitch in it. you may have another leak in the inlet pipe itself leading to the waterpump and thermostat. put some food coloring in the water, when it leaks it will pin point the POO (point of origin).
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 06-14-2005, 02:42 AM   #3
TheSnail
TheSnail's Avatar
TheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to all
Nore you did not use the gasket sealent properly (or the right sealent) or the water pump's seal its self took a crap.
TheSnail is offline   Reply With Quote
Old 06-14-2005, 10:28 PM   #4
AllenRPS13
AllenRPS13's Avatar
AllenRPS13 is an unknown quantity at this point
wrong forum...
please use the tech talk section
~小アレンのリベリオン~
いくせ, 勝負た! 轟こう, オレのKRMS13!!!
オレの得意技!蹴り進入!角度の少ないドリフト!
AllenRPS13 is offline   Reply With Quote
Old 06-14-2005, 11:39 PM   #5
altralosix
altralosix's Avatar
altralosix is an unknown quantity at this point
Are you sure it's not a leak from the hose dripping down the thermostat hosing? If not, yeah just go get a gasket and some sealer and do a good job with it.
altralosix is offline   Reply With Quote
