![]() Join Date: Jul 2004
More and more backfiring?
I have SR20 S15 for a while now and when I first got the car with the SR it never backfire or very very little. Now 7 months later it’s backfiring all the time. Manly between all shift points it will do a light backfire when it warms up. Is there a way to fix it to do less backfiring or is there something wrong with my SR?
97 240SX! 10 Camaro SS (SOLD - 95 W/S15 SR20 6M tran) |
#2 | |
![]() Join Date: Mar 2003
CA18DET t25, 440CC injectors, Greddy FMIC, Greddy Hot Pipe, Greddy Type RS Bov ,Greddy Turbo Outlet, Trust DP, Motoria 3" Catback , XS Tubular Manifold, Nismo AFPR ,Nismo Engine and Transmission Mounts ,Apex'i SAFC 2 Walbro 255lph, LSD, SPL Subframe Collars, Tein S Tech Springs, Tein Tie Rods, Upper Front and Rear Strut Tower Braces. Black 180sx wheels. |
![]() Join Date: Jul 2002
![]() ![]() Feedback Score: 3 reviews
if you run an atmo BOV recircing it will help some
possibly new plugs? Car may be running rich and therefore fouling plugs
I never knew you could do that with an eggplant |
#6 | |
#7 |
i just had the same problem, and i had to replace my fpr, just gave up on me and was sticking.
93 h/b. ka24de-t3(14), enthapy controlled .20bore, weistco 8.5.1cr, gReddy FMIC, E/L mani,t3 turbo to a 3in D/P to a HKS(88mm)HiPower and for cool sound effects the oldskool HKS Superblow, and you ask what about fuel? let me tell you 580cc, yes i said 580cc's, act clutch/flywheel. Buy my Coolio trading cardz! |
#8 |
![]() Join Date: May 2005
i agree with the timing or possible unburned fuel bein blown up cause of your EGT. If you really wanna get to the root of your problem, find out why back firing occurs in the first place.
Taking it a step further, why back firing occurs in turbo charged vehicles and try to apply what you learned to your situation. good luck. |
#9 |
So should I change all my plugs? If so what kind of plugs should I get? Well I have thinking that I'm running too rich. I go about 18 miles to the gallon. So thats no good. So should I go get my ECU tuned to fix the going too rich problem? By the way bdeisle, what fpr mean?
#11 |
depending on how bad the backfire.. i wouldnt drive or hit boost at all without knowing the issue, its not workth det. and blowing up your motor.. and in sr check coil packs and the ignitor
