Old 06-16-2005, 08:19 AM   #1
Jcb890
Jcb890 is making his/her stupidity well-knownJcb890 is making his/her stupidity well-knownJcb890 is making his/her stupidity well-known
Send a message via AIM to Jcb890
LSD question
1st off, I bought an LSD from a 180sx. Its from Japan. Will this fit directly with no modification or extra parts into my '93 240sx? the 240 has no LSD obviously which is the reason why I want to put this in. If I need any extra parts, what do I need? Also, does anyone have any good how-to's other than the one on the main page?
Jcb890 is offline   Reply With Quote
Old 06-16-2005, 08:46 AM   #2
Dousan_PG
Dousan_PG's Avatar
remove and replace
in and out
make sure both are 6 bolt on the side output flanges
and no problems.
Aaron
Pink GodziRa
Old 06-16-2005, 09:04 AM   #3
Jcb890
Originally Posted by Dousan_PG
remove and replace
in and out
and no problems.
i was hoping for a little more in-depth help than that...
Old 06-16-2005, 09:51 AM   #4
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Unbolt the 4 nuts on the face casing of the diff, then the bolts of the driveshaft and output shafts.
I personally unbolted all of the bolts on the driveshaft except one, so i could still spin it to reach the nuts and bolts of the output shafts. after you unbolt, get some kinda plyer, or screwdriver, and separate the outputshafts from the driveshafts. try hard, because its coupled. when thats done, there are 2 more bolts holding the diff up there. place a jack or somethin under the diff head (directly behind the casing head, where its most wide/heavy) unbolt those 2, and drop it down. When dropping it down, you'll have to wiggle it like your penis, until its loose, and come down easy. Don't drop this onyourself, cuz being the frail kid you are, it might kill you.
Then do everythin in reverse, and show your BF what you did, and call it a day, n snuggle.
SochBAT is offline   Reply With Quote
Old 06-16-2005, 10:03 AM   #5
Jcb890
umm... dont i need some tools to make sure its in there right so it doesnt whine/blow up on me?
aka dial indicator, an angle indicator, etc to make sure its in there perfectly so i dont ruin it????
Old 06-16-2005, 10:10 AM   #6
killjoy
killjoy's Avatar
killjoy is an unknown quantity at this point
Send a message via AIM to killjoy
Does it have the axles because they are 5 bolt.
stolen s13
new stock non-stolen s13
killjoy is offline   Reply With Quote
Old 06-16-2005, 10:16 AM   #7
Jcb890
it doesn't have the axels, all i have is the LSD itself.
here's some pics:
Old 06-16-2005, 10:36 AM   #8
Dousan_PG
Dousan_PG's Avatar
oh just the LSD
gte a shop to do it for you
you fuck up..it blows up
and no axles? your fucked. yeah. you are.
if its vlsd
you will need VLSD axles
if its LSD you might still need VLSD axles
expensive from dealer
rare at junkyards
you should have just spend 700 bucks or so bought a nismo lsd and then spent another 80 bucks getting in installed and been done.
now you ar down whatever you paid and if you need alxes you'll spend another hefty chunk of change plus install, and a good shop would usually recommond new bearings when you put the diff in, something aftermarket LSDs come with
Aaron
Pink GodziRa
Old 06-16-2005, 11:14 AM   #9
Jcb890
oh just the LSD
if its vlsd
rare at junkyards
so do i need the axles too??? i would think this will fit into the diff. casing on there now and i could use the stock axles... why wouldnt that work?
if you dont mind, when trying to help me out... use sentences that can be understood so i know what you're trying to say, lol.
Old 06-16-2005, 11:20 AM   #10
Dousan_PG
Dousan_PG's Avatar
no, stock axles DO NOT repeat DO NOT fit on vlsds
and most older aftermarket lsds as well
i tried to break it down so a retard could understand
but thats ok, let me try again
you tried to cut corners and save money
bad move.
now you are going to spend MORE money to get it to work
you need (if your unit is a VLSD)
VLSD axles (left and right)
new bearings
a shop to install it for you
then put the entire pumpkin on your car
you can use your current pumpkin but buy the parts before you swap in the guts of course.
that makes sense right?
Aaron
Pink GodziRa
Old 06-16-2005, 11:54 AM   #11
Jcb890
bad move.
new bearings
why do the stock axles not work? i'm curious.
Old 06-16-2005, 12:06 PM   #12
Jcb890
So it wont fit huh?
well... its for sale now then.
http://www.zilvia.net/f/showthread.p...385#post746385
Old 06-16-2005, 12:28 PM   #13
Dousan_PG
Dousan_PG's Avatar
vlsd and stock open diff axles are different, size..and splines iirc
Aaron
Pink GodziRa
Old 06-16-2005, 12:58 PM   #14
Jcb890
ah, gotcha. thanks for the explanation.
Old 06-16-2005, 01:06 PM   #15
Buffalo Daughter
Buffalo Daughter's Avatar
Buffalo Daughter will become famous soon enoughBuffalo Daughter will become famous soon enoughBuffalo Daughter will become famous soon enough
[QUOTE=Dousan_PG]
QUOTE]
HAHAHahah that made me crack a smile.
kick rocks.
Buffalo Daughter is offline   Reply With Quote
Old 06-16-2005, 01:12 PM   #16
Jcb890
well... i'll chalk this one up as a loss for me and try and sell it on here and buy a new LSD i guess.
i've been p0ned
on another note... the LSD is for sale
Old 06-16-2005, 02:36 PM   #17
boosteds13
boosteds13's Avatar
boosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really nice
Let's clear up some confusion for ALL the people here- The axles fit fine. It's the output shafts that do not.
"A CA? WTF is that? You shoulda got an SR yo."
View my vBPicGallery!
boosteds13 is offline   Reply With Quote
Old 06-16-2005, 02:53 PM   #18
Dousan_PG
Dousan_PG's Avatar
oop sorry i was watching video at same time
yeah output shafts, not axles sorry
Aaron
Pink GodziRa
Old 06-16-2005, 04:38 PM   #19
Jcb890
ok... so what do i need to put an LSD in this thing? New output shafts... but which one and where can I get them? I know from a junkyard... but the ones around here are really lacking in 240sx's.
Thanks in advance.
Old 06-16-2005, 04:40 PM   #20
Dousan_PG
Dousan_PG's Avatar
dealer
if you find it in a junkyard
just take the whole diff
much easier
Aaron
Pink GodziRa
Old 06-17-2005, 03:41 AM   #21
i8yourfwd
i8yourfwd's Avatar
i8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfection
Send a message via AIM to i8yourfwd
oh just the LSD
if its vlsd
rare at junkyards
Can you give me a link to that $700 Nismo LSD you speak of? Is it the whole rear diff and you just bolt it on? What would be the reccomended path (low cost, easy to install) to LSD for a 92 240sx?
http://jaythroughglass.blogspot.com
S13SilviaGirl: Mel are you that big?
i8yourfwd is offline   Reply With Quote
Old 06-17-2005, 04:50 AM   #22
SochBAT
VLSDs are craptastic! They mess up fast. IMHO, not worth it. I'd say get your open diff welded, and learn the ropes of 2way. Nismo GT Pro is a good upgrade after the welded diff. As with any 2way, there are chances you'll break your driveshafts. take the risk if you want. Learn how the weld reacts, then upgrade. and i'd say LSDs are and easy install. make sure you have the teeth matched up cuz if its not, you'll blow it to chunks. Anyone know where people could pick up those alignment tools?
Old 06-17-2005, 09:58 AM   #23
Dousan_PG
Dousan_PG's Avatar
its just the guts
i think it was 700 or so bucks
my friend got his at the nissan dealer
jspec sells diffs
kaaz diffs are cheap too
just hunt around
i grabbed a backup 2 way lsd used w/ a 4.3 drive for 500 bucks, full pumpkin
just hunt around
Aaron
Pink GodziRa
Old 06-17-2005, 10:25 AM   #24
Saisoku
Saisoku is on a distinguished road
I would drop $500 on a good 2way lsd with no questions asked right now. Where do you find deals like that?
Saisoku is offline   Reply With Quote
Old 06-17-2005, 11:11 AM   #25
Dousan_PG
Dousan_PG's Avatar
importers always get used LSDs
but remember its USED
so COULD be good COULD be shit
mine's in th emiddle
definately needs a rebuild
but im also comparing it to my NISMO SSS which i bought brand new and is completely badass
this USED one is for my beater 240sx and it had a 4.3 which is perfect for that low power KA on a s13
but i use s14 on my SR too because 4.3 and s14s work great together for drift.so do s13s
shit 4.3s just rule.
Aaron
Pink GodziRa
Old 06-18-2005, 03:19 AM   #26
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
eh dousan i hate u... LOL and i still havent found a decent price for those rr3 ebrake cables u speak of..
having the LSD installed isnt gonna be wise, because its gonna end up more costly, then just getting a vlsd diff with axles.... u want deals move to CA .. or find a local enough supply yard, that sells nissan parts...best bet...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 06-18-2005, 07:04 AM   #27
boosteds13
boosteds13's Avatar
its just the guts
jspec sells diffs
just hunt around
just hunt around
kaaz = nismo. Let's not forget 2-ways can be very dangerous in wet weather.
Old 06-18-2005, 08:58 AM   #28
Dousan_PG
Dousan_PG's Avatar
stfu
that is absolute BULLSHIT!
ive driven w/ a 2way lsd for almost 3 years
all season
friends back east do too
dont spread lies
totally fine in poor weather
just dont drive like a jackass.
and Kaaz is NOT NOT NOT NOT NOT NOT NOT NOT nismo
tomei=kaaz
kaaz and nismo are NOt the same!!
Aaron
Pink GodziRa
Old 06-18-2005, 01:15 PM   #29
AeBaSupLook
AeBaSupLook is an unknown quantity at this point
I think when everyone meant junkyard, they are refering to VLSD that came with the Infinite J30, 300z, etc. For a J30, it would have to be a 93-94 in order for it to work. They are right, if you do get lucky and find one at the yard, might as well take everything. Its has a 5 bolt output shaft along with axles that will fit a 240.. Good luck with everything, I got lucky and found a vlsd with axles just recently off a 93 J30.
-Kevin
AeBaSupLook is offline   Reply With Quote
Old 06-18-2005, 01:17 PM   #30
Jcb890
-Kevin
yeah, problem is, junkyards around here have jack shit for 240sx's... so we shall see. hopefully i can find something.
