Old 06-16-2005, 05:19 PM   #1
mixxamike
mixxamike's Avatar
mixxamike is an unknown quantity at this point
tricky electrical problem
So my s14 will not start...I started reading my FSM and worked my way back from the starter to the cluth interlock relay, still no power. I removed the clutch interlock relay and heard a click, put the relay back in and the car started right up. Here is teh kicker...before I did this, the accessories would not work either. This leads me to believe that its the ignition switch? After driving the car around for a bit after i managed to start it up, it died on my once again but I started the car right back up by removing and reinserting the clutch interlock relay...the car is now dead AGAIN in my garage.
any ideas?
mixxamike is offline   Reply With Quote
Old 06-16-2005, 08:20 PM   #2
skiboard06
skiboard06 is an unknown quantity at this point
maybe try replacing the relay i have a push button start for my sr i just got frustrated enough to do it
skiboard06 is offline   Reply With Quote
Old 06-16-2005, 11:23 PM   #3
mixxamike
mixxamike's Avatar
nevermind, i think its a short in my fuse box...not even with the aformentioned relay. its acutally the hi/lo radiator fan relay thats causing the problem...how??? i dunno, but if i move that relay all is fine.
Old 06-17-2005, 02:49 PM   #4
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
I was gonna say,,, it doesn't sound like an ignition switch at all if you move a relay and then it starts fine.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 06-17-2005, 08:30 PM   #5
Al_S14
Al_S14's Avatar
Al_S14 is an unknown quantity at this point
Send a message via AIM to Al_S14 Send a message via MSN to Al_S14
sounds to me like a faulty relay. i see a lot of Legends that have Fuel Pump relay start to go and car will shut off by itself when you hit a bump and banging on the relay can make it start again.
Al_S14 is offline   Reply With Quote
