Old 04-09-2002, 12:39 AM   #1
Drift Style S14
Drift Style S14's Avatar
Drift Style S14 is an unknown quantity at this point
Hey everyone i was wondering, what are the max hp the components of our ka's can handle? for example the pistons, connecting rods, crackshaft, etc. etc.
Drift Style S14 is offline   Reply With Quote
Old 04-09-2002, 04:03 AM   #2
DuffMan
DuffMan's Avatar
DuffMan is an unknown quantity at this point
Send a message via Yahoo to DuffMan
Pistons : 250 flywheel
Rods: forged but their durability varies. 300-400 depending on other factors.
Crank 400+
These are pretty safe numbers that I'm just pulling out of my ass to give you a general idea though. Some people put down over 300 hp at the wheels on all stock internals and have no problems. It's like a long expensive game of russian roulette.
DuffMan is offline   Reply With Quote
Old 04-09-2002, 10:19 AM   #3
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
There are a couple guys around now with b/w 300-350 hp on stock internals.  I would say the pistons can hold to about 300hp max before I personally would change them.  I think 250 is a fairly conservative estimate.
The pistons are definately the weak point though.
sykikchimp is offline   Reply With Quote
Old 04-09-2002, 10:40 AM   #4
geeaj
geeaj is an unknown quantity at this point
Rods and crank are forged from the factory. For anything over 250hp, I would suggest you shotpeen, polish, and balance the rods to overcome any manufacturing flaws or imbalances. Stock nissan rods are used successfuly in racing when prepped accordingly. No need to spend on aftermarket rods such as Carillo and such unless your building an all out race or drag car.
As for the crankshaft, you should have it magnafluxed, lightly polished, and magnafluxed. This doesn't cost much maybe $200. What you get in return is the some measure of security when you start cranking up the boost. The stock bottom ends are very stout IMHO, iron block, big mains, girdles...etc. Since your doing this, you might as well have the crank oil holes drilled a bit larger for increased lubrication.
Pistons are the weak link, I will agree. Enough said. You can go aftermarket as far as piston rings, something like total seal. But if your ring lands are of good design on the pistons, then OEM Nissan chromoly would be fine. Just make sure the engine builder has EXPERIANCE putting together engines. You can use the best parts in the world, have the best machinist, but if you skimp on assembly, your reliability will go downhill.
For extra protection, I would look into an aftermarket oil pan. One that provides increased capacity and preferably baffled to decrease oil "sloshing" during hard cornering or acceleration. Running higher oil pressure maybe a good idea too. Nissan motorsports sells a high pressure oil pump spring/washer set for the 280zx turbo, which can be modified to work on the ka oil pump.
Beware the fury of a silent man, be more cautious of his silent farts....
geeaj is offline   Reply With Quote
Old 04-10-2002, 11:51 AM   #5
Drift Style S14
So this brings up another question, what level of boost would i be able to run after work like that done to the motor? Also, roughly, how much would all this cost to build up the motor? thanks for the great info peps.
Old 04-10-2002, 09:44 PM   #6
guy
guy is an unknown quantity at this point
I am seriously thinking about the same thing.  I also was wondering roughly how much to spend on the engine work.
guy is offline   Reply With Quote
Old 04-10-2002, 10:00 PM   #7
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
i talked to a fellow 240sx owner who rebuilt his engine. he said with aftermarket piston heads and connecting rods, all machine work, and labor it came out to be $2,500.
you could probably run 25 psi on a properly tuned engine.
02 Blazer X - 90 240SX w/SR
oh noes
whateverjames is offline   Reply With Quote
