Old 06-25-2005, 10:53 PM   #1
Sil-EightyNY
Sil-EightyNY is an unknown quantity at this point
Send a message via AIM to Sil-EightyNY
Exclamation R32 Rear + 5 lug dont understand the ebrake system. Help!!!
I put my car in the shop with the plans of finishing the 5 lug swap today and did the front with no problems. The rear on the otherhand is a diffrent story. I got the 5 lug hubs and some R32 Malakas calipers and rotors. The problem is not putting them on but getting the ebrake to work. The rotors are very fat and look like the R32 uses both disks an drums in one on the rotor????? : Even if i get the Z32 e-brake lines, i dont think that there is a place to bolt them on???? Please explain the whole Z32 e-brake procedure cause the rotor is like a regular rotor, but the hab part sticks out and the inside of the rotor next to the hub is also shiny. If anyone has done this please tell me now cause i really dont want to put my stock rotors and brakes in the back. I need to finish this tomorrow. I have seen these on cars, i just dont know what i am missing and how to do it. I know i dont have the Z32 e-brake assembly.
Thanx
Tom
Sil-EightyNY is offline   Reply With Quote
Old 06-25-2005, 11:31 PM   #2
Sil-EightyNY
I just spent the last hour searching and found some helpful pics. So the z32 ebrake thing is only the drum part of the brakes and the caliper is for only the pedal??
I searched and I think i understand now but still not a 100%
Thanx
Tom
Old 06-26-2005, 01:43 AM   #3
drift into a curb
drift into a curb's Avatar
drift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond repute
Yup. Caliper uses the normal hydraulics for the brakes and e-brake uses the drums. You can install the e-brake cables later. But make sure to have the z32 dust shield/backing plate to retain the drum set up.
http://importnut.net/300zxbrakeswap.htm
Go big or go home!
drift into a curb is offline   Reply With Quote
Old 06-26-2005, 09:38 AM   #4
kenshinS14sks
kenshinS14sks's Avatar
kenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to behold
that's a very nice link drift
facebook.com/SodiumDanceCompany
kenshinS14sks is offline   Reply With Quote
Old 06-26-2005, 10:05 AM   #5
Indolent
Indolent's Avatar
Indolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura about
Send a message via AIM to Indolent
http://sportcompactcarweb.com/projec...cc_projsilvia/
another link/site, but not as detailed, shows you how to use the z32 cables w/o extending/splicing the cables, i did mine like how they did, but i don't think the link's working
Indolent is offline   Reply With Quote
Old 06-27-2005, 09:34 AM   #6
SirWarrior
SirWarrior is an unknown quantity at this point
I started doing mine this weekend. Its not that big of a deal to do. But a little more of a labor issue, as there is a lot of crap to do as opposed to the front conversion.
Than again I got the complete ebrake assembly, but the pad were worn out, so I had to actually replace those. No biggie, just labor/time
92 FastBack - Project
98 SE - Daily Driver
SirWarrior is offline   Reply With Quote
Old 06-28-2005, 12:08 AM   #7
Sil-EightyNY
Almost done. I slaved the whole day in the junkyeard since they said "I aint doin it". The car was on the floor and took a very long time but i got the e brake assembly and the master out of a 300zx. Now i put everything together and now just connected the stock 300zx ebrake lines. I just now need to figure out a way to mount them and tension them. Here take a look at my 240sx Type R LOL
My 240sx Type R
Old 06-28-2005, 10:09 AM   #8
SirWarrior
Mine is still not done.
I need to remove the stock rear brake line, but need a 10mm flare wrench, cuz my regular was slipping. Than I went to DDC, and I didn't really wanted to mess with it after. But going to finish up today
Old 06-28-2005, 10:52 AM   #9
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
thats so nice heliping newbies............ awwwwwweee...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 08-02-2005, 11:21 PM   #10
Twinturbozs
Twinturbozs is a well-known jackass
how hard was it to remove the hub? did you remove the driveshaft to get the ebrake cables to hook up?
Twinturbozs is offline   Reply With Quote
Old 08-02-2005, 11:25 PM   #11
Dousan_PG
Dousan_PG's Avatar
s13 with z32 lines fit perfect, i had that
z32 lines on s14..ah a bitch
etend or get skyline ones
i got them from YANACK japan, its froma a Skyline R32 type M (gts) model iirc. i think r33 gts and r34 fit ok too (ER34)
Aaron
Pink GodziRa
Old 08-02-2005, 11:44 PM   #12
drift into a curb
Are the Yanack ones a full cable? Or is it just an extension? I got some from JP that were just an extension that pops on to the z32 cable, but they weren't even bolt on. I had to make my own custom mount to hold the cables, so they were properly tensioned. The idea came from some guy on freshalloy that made a proper mount for his cables, so I believe pictures are floating around there somewhere too.
Go big or go home!
Old 08-02-2005, 11:49 PM   #13
Dousan_PG
Dousan_PG's Avatar
full cable, brand new.
retail i think is about 150 USD?? plus whatever an importer will rape yo uwith
i just had some friends bring them over for me and paid them.
should be putting them on thursday??? i hope...
Aaron
Pink GodziRa
Old 08-03-2005, 01:01 AM   #14
Indolent
Indolent's Avatar
when i had to make my own mounting brackets for the z32 lines, i just cut the rubber part off the s13 ebrake cables to take the bracket out and put them on the z32 ones, i'd show pics but i dont' have my own cam, didn't wanna make any custom brackets, got lazy, but hey it works just fine
