Old 06-27-2005, 09:51 PM   #1
sLiDewAys
sLiDewAys is an unknown quantity at this point
tein HE height problems....
okay so i bought these new long over a year ago and began adjusting the height with the spring seat like an idiot....... not shure how much i lowered the car but i red the manual and adjusted them back to factory spec and then lowred from the strut shell. the height adjustabliliity is maxed but i still have 2 finger gap in the rear... i have 16's on 50 serries... n that doesnt sound right..anyhow i was just wondering if anyone else has had the same problem,,,
sLiDewAys is offline   Reply With Quote
Old 06-27-2005, 09:55 PM   #2
Dousan_PG
Dousan_PG's Avatar
thats how tein HEs are
they dont go low in the rear.
Aaron
Pink GodziRa
Old 06-27-2005, 10:00 PM   #3
sLiDewAys
GAY.
looks like i'll have to soften the spring rate in order to kill this wheel gap
NOT COOL AT ALL
Old 06-27-2005, 10:03 PM   #4
raen419
raen419 is an unknown quantity at this point
Send a message via AIM to raen419
and people wonder why others say HE's are overrated.
add that reason to the list.
raen419 is offline   Reply With Quote
Old 06-27-2005, 10:09 PM   #5
sLiDewAys
i got them when they first came out for super cheap.... under 1100 which is the only reason i bought them.. oh well. softer spring rate = less bounce i guess AHAHAHHAHA
Old 06-27-2005, 10:49 PM   #6
BOMEX180
BOMEX180 is an unknown quantity at this point
I had less than a finger gap in the rear when I adjusted my HE's. I sold them and switched to drift spec
BOMEX180 is offline   Reply With Quote
Old 06-27-2005, 11:12 PM   #7
Dousan_PG
Dousan_PG's Avatar
what tire size and wheel?
this guy said his
1 finger gap is one finger too much, imo.
Aaron
Pink GodziRa
Old 06-27-2005, 11:27 PM   #8
ghambino
ghambino will become famous soon enoughghambino will become famous soon enoughghambino will become famous soon enoughghambino will become famous soon enough
I don't know much about the HE's, but why can't you lower the spring seat slightly to compensate for the gap? Most lower-end coilovers adjust height only from the lower spring seat. Just don't lower the lower spring seat so much that you sacrifice suspension travel.
ghambino is offline   Reply With Quote
Old 06-28-2005, 03:45 AM   #9
ootranceformeroo
ootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to behold
Send a message via AIM to ootranceformeroo
Tein HE almost maxed. 17in rim with a 45 series sidewall. In the rear mine is tucked about 10mm +?
Gorgeous Garage
Touge Friends
CrabDrifting.com
Drift Unit
ootranceformeroo is offline   Reply With Quote
Old 06-28-2005, 08:56 AM   #10
Yuri
Ghost of Zilvia past
Yuri's Avatar
My rears tuck too, and they can go much lower. I'm running a 215/45-17 on my S13.
Yuri is offline   Reply With Quote
Old 06-28-2005, 10:58 AM   #11
sLiDewAys
im running 16x8+27's w/ -1.7 degree camber rear and -2.2 degree camber front... the front is maxed out yet and i can still lower it another 2 inches or so until it has maxed to the spring seat and lock. but the rear on the other hand has maxed. I understand that the closer the wheel is to 0 the more it will stick out and with my experience on 0 offset they will flushen up on the fenders w/o even lowering the vehicle.
for instance i had 15x7+20 and they were sunken in with the same height, i opted for 0 offset and they sat flush w/o any tire gap so maybe when and if i run some 15+mm spacers it will get rid of the gap.. time to make a run to the local tire shop for some bolt on spacers... let you guys know how that work out later.
brandon
