Old 06-29-2005, 10:15 PM   #1
ka24det-power
ka24det-power's Avatar
ka24det-power has a little shameless behavior in the past
HKS 264 Step 1 Cams - Vacuum lower?
I just installed my HKS 264 Step 1 Cams. Went pretty smooth the only issue I have is that it wants to stall when I let the motor drop from high RPM's to idle. I am only getting about 14 to 15psi of vacuum at idle. Before the cams it was 19 to 20psi of vacume.
I adjusted the IAV to raise the idle (which it does) but it still wants to stall when I drop it from high RPM's. I did a vacuum check and I have no leak. I have a GReddy intake mani as well.
Is this normal what should I check?
ka24det-power is offline   Reply With Quote
