Old 06-30-2005, 12:09 AM   #1
mixxamike
mixxamike's Avatar
mixxamike is an unknown quantity at this point
Wheel clearance on compressed coils
I'm working on my wheel setup right now and I need a spacer. With my car's suspension completely released, I can fully bolt my wheel and tire onto the front hub. The problem: it JUST touches the coil enough to keep the wheel from moving. If i would put a 15mm spacer on i would have just that: 15mm of clearance between my wheel and my dreaded tein HEs.
I'm just curious as to how the susupension geometry changes as the shock body is compressed. Will the top of my wheel move even closer to the coil or will it stay that same 15mms away even at full compression? Depending on the answer to this question, I may have to order even large spacers to accomodate for camber.
thanks
-mike
mixxamike is offline   Reply With Quote
