Old 04-11-2002, 04:54 PM   #1
blink0r
blink0r is an unknown quantity at this point
I'm mad, and i'll make this quick. I plugged in the wires to my new sidemarkers, and they worked. I put silicon on my new lights and slid them into place, but now NONE of my 4 sidemarkers work. Do they have their own fuse, or what could the problem be? Please  help ASAP!
1991 Nissan 240sx SE
"Friends don't let friends drive trucks."
blink0r is offline   Reply With Quote
Old 04-11-2002, 05:15 PM   #2
Broadwayblues
Broadwayblues is an unknown quantity at this point
Send a message via Yahoo to Broadwayblues
Dude that sucks! It's hard to say. I would get a curcuit tester, one of those pens that lights up if you put it next to a 'hot' wire and trace the wires back until you find power. Can you pop the lights out and look at them again? good luck!
"stop lights timed to 55 mph are also timed to 110 mph!"
http://www.geocities.com/broadwayblues34/240sx.html
92 240SX Coupe!
MB clear side markers Clear bumper lights
3 inch universal muffler w/ removable tip.
Strut tower bar- Front
OBX SS version 2
Broadwayblues is offline   Reply With Quote
Old 04-11-2002, 05:22 PM   #3
hookedup240
hookedup240's Avatar
hookedup240 is an unknown quantity at this point
Send a message via AIM to hookedup240
What kind of side markers are they the mercedes ones or just other aftermarket ones? Are they clear?
hookedup240 is offline   Reply With Quote
Old 04-11-2002, 07:45 PM   #4
blink0r
I found out the problem. Turns out that the 2 metal disconnects were touching each other, causing my fuse to burn out (the sidemarkers are wired into the tail light fuse). I put tape between the 2 disconnects and VOILA!
PS: Yes, they are the mercedes lights.... i had to grind one of them down for a good hour, took me about 3 hours to install the one light.
Old 04-11-2002, 08:07 PM   #5
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
yah i had the same problem...wired them all up, ready to leave, and none of them light up...yah they were touching, so there went my fuse.  i did them for the rear also, but they do not fit as well and i had to silicone them up real good.  also my reverse lights dont work now, blinkor you should check yours. late
rancid240 is offline   Reply With Quote
Old 04-11-2002, 09:18 PM   #6
blink0r
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (rancid240 @ April 11 2002,9:07)</td></tr><tr><td id="QUOTE">yah i had the same problem...wired them all up, ready to leave, and none of them light up...yah they were touching, so there went my fuse. i did them for the rear also, but they do not fit as well and i had to silicone them up real good. also my reverse lights dont work now, blinkor you should check yours. late</td></tr></table><span id='postcolor'>
Why don't yours work? Have you fixed them?
&quot;Friends don't let friends drive trucks.&quot;
Old 04-11-2002, 09:33 PM   #7
rancid240
Trader Rating: (72)
i have no idea why the reverse dont work. &nbsp;I have checked all fuses, and it is odd for both of them to go out at the same time...but i think it has something to do with the fuse going out on the sidemarker install. &nbsp;Dont we have a reverse sensor or something on our trannys? &nbsp;Even though i dont think that had any reason to go out, its worth a try.
Old 04-11-2002, 11:07 PM   #8
bing
bing will become famous soon enoughbing will become famous soon enoughbing will become famous soon enoughbing will become famous soon enoughbing will become famous soon enough
i havent had reverse lights in i dont know how long...
im gonna do the side markers soon, did you guys change to bulbs??? what all will i need
www.son240sx.org /// www.nyspeed.com
bing is offline   Reply With Quote
Old 04-12-2002, 01:39 AM   #9
blink0r
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (bing @ April 12 2002,12:07)</td></tr><tr><td id="QUOTE">i havent had reverse lights in i dont know how long...
im gonna do the side markers soon, did you guys change to bulbs??? what all will i need</td></tr></table><span id='postcolor'>
They are sidemarkers for a Mercedes ML 320. Go to a mercedes dealer and ask for part #163 820 01 21. You'll need 2 of these, they come individually boxed and cost about $6 US per light.
I'll make a long story short. They're way too big to fit into the stock sidemarker holes so you can either:
A) File down the stock sidemarker holes (not recommended)
B) Grind down the sidemarkers with a dremel hand held tool or a bench grinder; sand paper will NOT work.
Here's what they look like installed:
If you have any other questions, let me know.
