Old 08-05-2005, 12:25 AM   #1
xagna
xagna has a little shameless behavior in the past
A question about adjoustable lower arms
I want to get adjoustable lower arms for front and rear suspensions to improve the roll center locations.
Does any one know any other brands besides SPL that makes adjoustable lower arms? The ones by SPL are too expensive; $1200+ for all four.
If you could teach me any place that I can get these at lower prices, I would appreciate a lot.
xagna is offline   Reply With Quote
Old 08-05-2005, 12:35 AM   #2
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
Ikeya Formula makes them as well but they probably cost more. Seeing as how I read your other post about how the only thing you have on your car is megan coilovers, there are so many other things you should be investing your money in.
Flybert is offline   Reply With Quote
Old 08-05-2005, 01:58 AM   #3
projectRDM
projectRDM's Avatar
Adjustable LCAs/Aarms are pretty useless unless you really need more camber correction than regular camber plates and upper arms allow. I wouldn't bother with either until you've done everything else under the car and you're looking to eliminate the last bits of rubber that remains.
FORMERLY R240NA
