Old 08-08-2005, 04:27 PM   #1
1 88 U
1 88 U's Avatar
1 88 U is making his/her stupidity well-known1 88 U is making his/her stupidity well-known1 88 U is making his/her stupidity well-known1 88 U is making his/her stupidity well-known
flywheel removal without impact gun
Any other methods or trick for removing the flywheel bolts without using an air impact gun?
1 88 U is offline   Reply With Quote
Old 08-08-2005, 06:04 PM   #2
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
jam a screw-driver in the outer holes
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline   Reply With Quote
Old 08-08-2005, 06:07 PM   #3
aznpoopy
aznpoopy's Avatar
it'll snap in half unless its a super beefy screw driver
but yes, take a pry bar and jam it in between the teeth
use a big breaker bar on the bolts
aznpoopy is offline   Reply With Quote
Old 08-08-2005, 07:02 PM   #4
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
yah its a good thing I used a craftsman screwdriver when I did it, ended up waiting till I got a compressor though to take the flywheel off.
mjjstang is offline   Reply With Quote
Old 08-08-2005, 07:50 PM   #5
projectRDM
projectRDM's Avatar
Brace the crank pulley with the proper socket and a breaker bar against the frame rail.
FORMERLY R240NA
Old 08-08-2005, 08:56 PM   #6
kandyflip445
kandyflip445's Avatar
Flywheel Turning Tool. But that up against something on the car then use a breaker bar for the bolts. That or what Russ said.
My 240 vBgarage
Old 08-08-2005, 09:19 PM   #7
ucfz31s13
ucfz31s13 is an unknown quantity at this point
Send a message via AIM to ucfz31s13
grow a pair and put some muscle behind it!
ucfz31s13 is offline   Reply With Quote
Old 08-08-2005, 10:39 PM   #8
Nissandriver714
Nissandriver714 is an unknown quantity at this point
go to sears and get a long breaker bar ( about 2-3 feet long). use one of the clutch bolt ( bolt that you use to tighten the pressure plate to the flywheel) and screw it onto the flywheel, then use a long bolt from the transmission and screw it into the place where the transmission meets the engine (areound the 10 o'clock positon). Then spin the flywheel and wedge the breaker bar between the 2 bolt. the flywheel should stay put, you can then use another breaker bar and open the fly wheel bolts. I've done this many times and it works great. Sorry, i can't find the right words to explain it clearly. I hope that helps.
Nissandriver714 is offline   Reply With Quote
Old 08-08-2005, 11:09 PM   #9
S14DB
AFC #1
S14DB's Avatar
I broke them loose with a big breaker bar. The engine never turned over.
Old 08-09-2005, 09:09 AM   #10
SirWarrior
SirWarrior is an unknown quantity at this point
that can't be good.
92 FastBack - Project
98 SE - Daily Driver
SirWarrior is offline   Reply With Quote
Old 08-09-2005, 09:44 AM   #11
lilredstiffy
lilredstiffy's Avatar
lilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to all
Send a message via ICQ to lilredstiffy Send a message via AIM to lilredstiffy
screwdriver between flywheel tooth and ground works great for me
anything else is too much work
lilredstiffy is offline   Reply With Quote
Old 08-09-2005, 10:36 PM   #12
smily_vigor
smily_vigor's Avatar
smily_vigor is an unknown quantity at this point
Send a message via MSN to smily_vigor
Lightbulb Call a buddy
Tools needed:
One friend (buddy), 27mm socket, 1/2 drive 19mm socket, breaker bar, and 1/2 drive ratchet, and the pipe.
- Put the 27mm socket on the breaker bar and have your buddy hold it on the main crank pulley bolt. (breaker bar should be long enough that he can hold it up in the engine bay)
- You, yourself take the 19mm socket on the ratchet and use that (with the bar for leverage) to loosen the flywheel bolts.
Your buddy holding the main crank pulley will stop the engine (and flywheel of course) from turning, with a little froce (the longer the pipe the easier it is) you should be able the crack all the bolts
smily_vigor is offline   Reply With Quote
