Old 08-10-2005, 06:43 AM   #1
Rkesh88
Rkesh88 is an unknown quantity at this point
90 hatch tail lights
i have a 90 hatch and the reverse lights dont work, changed the fuse, new blubs everything, any suggestions?
Rkesh88 is offline   Reply With Quote
Old 08-10-2005, 07:03 AM   #2
smily_vigor
smily_vigor's Avatar
smily_vigor is an unknown quantity at this point
Send a message via MSN to smily_vigor
Lightbulb Try these
Get the wire diagram (I think it's in the tech section of this website) trace it back to the sensor on the transmission. It might be bad resulting in the car not knowing it's in reverse so the lights don't go on. It's pretty simple to change out but you might not be able to find it anywhere other than the dealer.
Also you can make sure that all the connections to the bulbs are clean, sometimes corrotion can make then stop working. You can also whip out the multimeter or test light and make sure you are getting power back there at the lights when you're in reverse.
smily_vigor is offline   Reply With Quote
Old 08-10-2005, 10:41 AM   #3
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
+1...mine dont work either, ever since I blew the tail lamp fuse. Pretty sure its the tranny sensor.
rancid240 is offline   Reply With Quote
Old 08-10-2005, 12:59 PM   #4
projectRDM
projectRDM's Avatar
It would almost have to be the switch, the power that feeds the reverse lights come from the gauge cluster circuit so if they're working than the circuit to the switch is fine.
They actually don't list that anywhere in the FSM, I found out by replacing a transmission with a lower mileage, although beat up unit, the reverse switch had been crushed and everytime I shifted into reverse the gauges would die. Unplugged the switch, never blew a fuse afterwards.
FORMERLY R240NA
