Old 08-12-2005, 09:39 PM   #1
sXi
sXi is an unknown quantity at this point
steering rack bushing
I was shopping for steering rack bushing ..
and found the following..
the rubber ones..
and ..
the alum ones
from the research i 've done. I know the alum one is direct replacement.. what about those rubber ones? where do they go?
thanks
sXi is offline   Reply With Quote
Old 08-12-2005, 11:06 PM   #2
kandyflip445
kandyflip445's Avatar
Those don't even go in the same place.
The first is urethane and holds the rack in place.
The second goes in the steering column.
My 240 vBgarage
Old 08-12-2005, 11:25 PM   #3
sXi
yeah.. the alum one is go in between the sections. I seen my friend installed it before.
I want to know where to install the rubber ones. do you have any pictures? And I asked my Friend, He said he didn't see anything like that on his steering rack nor column
Old 08-12-2005, 11:33 PM   #4
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
Your friend is booboo.
Look at the rack, which is resting on the crossmember. (read: Get under the car)
If you look at the two points where the rack "rests" on the member, you will see the bushings.
kazuo is offline   Reply With Quote
Old 08-12-2005, 11:38 PM   #5
sXi
how come spl has 2 designs for the rubber bushing? and those are the engergy bushing on spl's website
Old 08-12-2005, 11:59 PM   #6
kandyflip445
One goes on the drivers side and one goes on the passenger side. If you get under the car you'll see it. Look at where the lines go in the rack and you'll see the bushing next to it. The passenger isn't far from it, just on the passenger side.
AGAIN. THEY ARE NOT RUBBER. THEY ARE POLYURETHANE. NISMO ARE RUBBER.
My 240 vBgarage
Old 08-13-2005, 01:39 AM   #7
sdtouge
sdtouge can only hope to improve
anyone tried the metal one? how did it feel? was there a big difference or not? i was thinking mayube just install on of those and the bushings while my motor is still out. so if some has some feedback post it up pleaseb
sdtouge is offline   Reply With Quote
Old 08-13-2005, 01:56 AM   #8
CHARLIE2020
CHARLIE2020 is an unknown quantity at this point
Send a message via AIM to CHARLIE2020 Send a message via Yahoo to CHARLIE2020
Some S13 dont have a need to add the aluminum bushing because there is a steel one there allready while other S13 sometimes have a rubber bushing, you just have to look.
CHARLIE2020 is offline   Reply With Quote
Old 08-13-2005, 06:40 AM   #9
KOUKI KA-T
KOUKI KA-T's Avatar
KOUKI KA-T is on a distinguished road
Well only one of them is urethane.
They package the ES urethane bushing with the nismo (round) rubber one.
Why, if you don't know where they go or if you even need them, are you shopping for them?
My car has been sold
KOUKI KA-T is offline   Reply With Quote
Old 08-13-2005, 08:03 AM   #10
sXi
lol. my motor is out. trying to do some upgrade
Old 08-13-2005, 09:03 AM   #11
kandyflip445
Meh. The s14 has the combo. The s13 set is both urethane. If your engine is out and you have the money just do both. They aren't that expensive.
My 240 vBgarage
Old 08-13-2005, 01:08 PM   #12
projectRDM
projectRDM's Avatar
The combination of the ES/Nismo set is only for the S14 rack, the round bushing in the ES set won't fit since the rack is slightly smaller is diameter. For the S13 and Z32 racks, both ES bushings are the correct size and work fine. You can also put an S13 rack into an S14 in order to use the ES set, like I did.
The aluminum piece is a spacer to replace the rubber unit in the column, not the rack, only found on S13s. S14 columns don't use it.
FORMERLY R240NA
